I'd definitely recommend it. I swear the areas of rust that was disintegrating just bonded right up with the POR-15 and is now rock hard.
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
Made a note, and put it on my calendar. I'll answer that question in 5 years. LOLOriginally posted by DeLaRosa25 View PostHow long would it hold up for years wise? With me obviously using my camaro as my DDsigpic
I doubt Angie would go for that unfortunately.
Post Whore-ess
Owns Meissen
- November 13th, 2005
- 9510
- Angie Meissen
- 2002 W68 Firebird, 3800 Series II V6
- Chesterfield, Mi
- Operator/ Receptionist
Originally posted by nascarnate326 View PostLooks good Brian. You should have one helluva weekend next weekend
Hear it run will be like a first child screaming lol
So ya, whats next? LS1 into Angies car?
As awesome as that would be I don't have the time or money to put into the car and I don't drive the car enough to do all that work.*Angie*
looks good brian! the engine bay looks killer. if i were you i would just go grab some spray on RUST STOP from ace and do a quick once over on the undercarriage. it's cheap and it'll even everything out where you have thin spots that didnt quite cover the red.2000 Trans Am l 1967 Firebird
3200-3400 with a 2 STR I think.
Got the rear end mostly in today!!!
Still have more work to do, but we had to make a lot of runs to get the right bolts and stuff.
By the way - I would definitely NOT recommend using Energy Suspension's rear sway bar bushing kit. The bolt they give you is a good 1-2" too short. Kyle has comparison pics. I had to go to Murrays and buy a new rear sway bar bushing kit ($10) just so I could use the proper length bolt from that kit with the poly urethane bushings.
isnt that intentional for a more effective sway bar?-Joel
