  • Did pretty much all of the passenger side tonight. Still have to do another coat on all of it to fix the areas where you can see through the paint to the red. Had a little boo-boo while I was tearing out the LED underbody bar. Knocked the POR-15 can over - spilled paint all over the floor. Anyway, here's pics... shitty pics, but pics none the less:
    • I spilled pvc primer on my carpet once...parents didnt appreciate
      • looks like you missed a few spots. DIY hard to find good help
          • Brian do you plan on using that 2 piece steel driveshaft you have?
            • Looks good...
              ...but messy messy messy!!!
              Next time, glue the paint can to the floor.
              I know how tempted you are to see what happens when you tip it, but resist. Resist!!!
                No sir - sold it awhile ago. LT1 came with a steel driveshaft that I intend to use.
                • looking good - whens the last time you replaced the filter?
                  • Wow...didn't even notice the fuel filter floatin there...
                    • Last time it was replaced was... prior to 2002 - haven't replaced it since I bought the car. I was definitely thinking about doing it while I'm under there though.
                      ...and thought about replacing the brake lines...
                      ...and the torque arm...
                      ...and yank the EVAP (since I'm going to need to do that anyway)
                      • Ya, time for a replacement.
                        • fresh engine needs all fresh filters - start soaking those fittings now with wd40
                          • 15 pages later I am caught up again, great work Larry & Brian!!!!
                            • Originally posted by TSTONE View Post
                              You DON'T want to strip or round off those fittings!!!
                                that should not be so much the issue, more that if they havent been moved in 7yrs the fittings are likely seized to the lines
