I have never heard that term before?
You can degree a cam with a standard chain.
The nerdy work part of me wants to do a project plan in Microsoft Project to get everything scripted out and make sure I can get it done in time and set deadlines.
I seriously almost did that with mine too! but then when we tore apart the whole thing in one evening i realized i had no idea when people were going to be there to help so i didnt.
I didnt degree mine Dot to dot is fine unless you really want it perfect IMO.
You degree it to make sure you didn't roll the camshaft when you put the timing chain on.
Not trying to scare ya B but you might want to take the time to check stuff now instead of finding out after it's too late.
That's my
Oh I know the camshaft is in right and the gears are lined up. I mean, when the timing chain went on the dots were perfect 6 o'clock for the cam gear and 12 o'clock for the crank gear with the cam at #6 TDC.
You can line up your dots all day but if you turned the cam a little to get the bolts in then it's wrong.
The guy down the street from me does motors for Weller and he degree's everything to make sure nothing got moved from a simple rebild 350 to a 572.
I'm just saying.....
I'm still trying to figure out how you could roll the cam and still have the dots line up. It would seem like if the cam rolled out of alignment at all that the dots would be misaligned.
