Jonny! It looks hawt! If you don't mind me asking what did it run you to get the wheels widened? Looks great!
2002 Z28 Camaro A4 1993 Z28 Camaro M6- SOLD 1999 Z28 Camaro M6- SOLD 2008 Ford Fusion SE - DD
It was $300 per wheel. Typically it is $200 ish a wheel but because I had these widened to the Lips it was a little more. More work goes into it for widening to the lips such as grinding down the welds on the lip side so it is smooth for refinishing!
Worked a little more last night. Took them from 600 to 1200 and then to 2000. The polish I have isn't very good, hoping to pick up the good stuff here to make these pop even more!
1200 grit
2000 grit
Added a little polish by hand
Comparison of the polished vs the other one I still have to start!
Hey Jonny....it's been my experience that you will never be able to completely polish out the weld seams on aluminum. The finer you polish it the more it will stand out. You might find that you will have to settle for a fine brushed look. With regards to the polishing...what i do after 2000wet is use a 3m fine rubbing compound, then 3m Finesse compound, then actual mothers aluminum polish followed up my mother's billet. That will make it look better than chrome.
awesome, thanks for the tips!! Going to polish up the other one here in a few minutes, had to go get more sandpaper!
thats typical for these corvette owners they like that gaudy look
Corvette pricks! I been thinking about taking my 16s off to put 15s on.
BTW you have wheel flares.. I wouldn't call it a wide body. This a widebody.
This a 1976 that was made by greenwood in the 1976. A Corvette was $8,000s then, this model was 16,000. vemp-1106-12+ken-lingenfelter-corvette-collection.jpg
