Pics with CCW's are needed...
Vette Progress
Grammar Nazi
- January 10th, 2006
- 6647
- Jonny
- under par
- Huron Speed
Grammar Nazi
- 6647
- Jonny
- under par
- Huron Speed
awesome thanks mike!Originally posted by c0ncEpT View PostI have a few videos Jonny. I'll post them up later.
I am using the Nitrous Express EFI Race Nozzle kit. 100 hp pills.
Put car on dyno immediately before I left for Milan and it made 405/371 on motor and 495/492 on the spraysigpic
Grammar Nazi
- 6647
- Jonny
- under par
- Huron Speed
VERY happy with it, it's awesome! I literally decided last week I wanted to go faster for this track day so I called NX and ordered the kit. Being they are in Texas I did not get it until Friday. I tossed the kit on Friday night. Wired it up Saturday after work. Tossed it on the dyno right after at about 4pm. We made a couple NA pulls to check it out, then made some quick nitrous hits. Then a full nitrous pull and it started breaking up a bit. Headers hot as helllll swapped out the TR55's for some TR6's and made another pull... completely clear! Pulled off dyno and drove straight to Milan. Swapped wheels and first pass sprayed it. I don't have any gizmos, just a WOT switch and it worked flawless. Made 5 passes, first bogged, second spun, last 3 were all decently better launches at 1.6 60' VERY happy!Originally posted by sman View PostNICE! Happy with it?
I was really considering a plate kit, not sure which way to go.
What plugs are you using? Thats really close to the power range I would be in.sigpic
Grammar Nazi
- 6647
- Jonny
- under par
- Huron Speed
Thanks Larry! Bottle pressure was about 750 so I have a heater on order. With proper pressure I don't see why it wouldn't go 10.80'sOriginally posted by OIF1VET View PostHoly shit dude.. Your car is a work of art..... Absolutely gorgeous....... and the 11.04 doesn't hurt!!!sigpic
Yep, bottle pressure around 950 will make a difference.. Have you considered running br6ef's? I changed over this year, a lot of nitrous guys now recommend the non-projected tip..Originally posted by Superman09 View PostThanks Larry! Bottle pressure was about 750 so I have a heater on order. With proper pressure I don't see why it wouldn't go 10.80'ssigpic
Grammar Nazi
- 6647
- Jonny
- under par
- Huron Speed
no idea, never really looked into it. The TR55s weren't having any of it so I tossed in the TR6s and it worked great. If I run into any issues I'll check them out, thanks!!!Originally posted by OIF1VET View PostYep, bottle pressure around 950 will make a difference.. Have you considered running br6ef's? I changed over this year, a lot of nitrous guys now recommend the non-projected tip..sigpic
I never had an issue with the TR6's either.. Just read about the BR6EF's and decided to try it out.. My car ran awesome all year...Originally posted by Superman09 View Postthe TR6s and it worked great.sigpic
