Originally posted by birdie2000
View Post
Nitrous?
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
Really a 4AN will just screw right onto the test port?Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
Lurker
- March 13th, 2010
- 3476
- TJ
I knew that but I couldn't spell it and the spell check on Firefox wouldn't fix it so I just left it out. HahaOriginally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Going to be ordering my kit here soon, just had to pay to tuition last week =/
I need some info.
Where in the intake elbow should I put the nozzle?
Good mounting location for Mallory 685 and NX proton module?sigpic
1996 Base Model
+2 cylinder mod
Lurker
- March 13th, 2010
- 3476
- TJ
All of it can be installed in my car. Thats a good location.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Wow! Jonny, I will definitely be talking to you soon about that kit. That's a great price! I already have the MSD 6al2(two step) on my car, I wanted to go 150 shot, but for the price you can't beat that.Originally posted by Superman09 View PostI always try to help out the local guys!Pacesetter LT's, Pacesetter ORY, full MSD ign., 2 step, rear LCA's, SFC's, B&M Ripper, poly motor mounts, Nitto NT05R's, WS6 wheels, KYB AGX adj. suspension, Eibach Sprotline springs, Trickflow elbow w/K&N, All HVAC deleted w/ delete panel, no AIR, No EGR
96 Z28 Camaro M6
2008 Silverado quad cab LTZ
A lot of people mount the Ign. box on the drivers wheel well under the hood or below the intake elbow on that same wheel well. However, if you have deleted all your HVAC, like me, and installed a delete plate, put it right on that. Best spot ever imo. Reardless, keep it away from heat and definitely use the rubber mounts to reduce as much vibration as possible... heat and vibration do bad things to ignition modules! And make sure you install it to where your dials are easily accessible.. don't wanna have to unbolt a bunch of sh*t everytime you wanna mess with rev limiters or timingOriginally posted by jderry View PostGoing to be ordering my kit here soon, just had to pay to tuition last week =/
I need some info.
96 Z28 Camaro M6
Lurker
- March 13th, 2010
- 3476
- TJ
I have heard that but I also heard the ignition modules throw out a lot of heat. I like Justin's idea of the HVAC spot.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Lurker
- March 13th, 2010
- 3476
- TJ
There is no need to high an ignition box.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
I have my window switch and retard box where the battery goes (my battery is in the back).... If your running an ls1 lid you could put it where your cai use to go, if not your probably going to have to stuff them inside the car.
I don't care about hiding the box, just figured I don't use my glove box and it'd be an easy place to change stuff on it.
I want to hide the nitrious stuff.sigpic
1996 Base Model
+2 cylinder mod
So I have the Mallory, ordered my kit from Jonny.
Now I need to figure out where to put everything.
I am thinking of putting solenoids under the PCM, I want to hide this setup as much as possible.
Can I put the Nozzle on the bottom of my intake elbow without losing out on anything?
Is it better to have it vertical? Horizontal? Facing the TB on an angle?sigpic
1996 Base Model
+2 cylinder mod
