Nitrous?
  • #46
    Originally posted by birdie2000 View Post
    Test port on the rails accepts a -4AN fitting. Just remove the valve then run a -4AN hose from the test port to the fuel solenoid. Done.
    Really a 4AN will just screw right onto the test port?
    Originally posted by Yoshi94
    • #47
      Yessir
      • #48
        Schrader valve is the term yall are looking for
        • #49
          I knew that but I couldn't spell it and the spell check on Firefox wouldn't fix it so I just left it out. Haha
          • #50
            Going to be ordering my kit here soon, just had to pay to tuition last week =/
            I need some info.
            Where in the intake elbow should I put the nozzle?
            Good mounting location for Mallory 685 and NX proton module?
            1996 Base Model
            +2 cylinder mod
            • #51
              All of it can be installed in my car. Thats a good location.
              • #52
                Originally posted by Superman09 View Post
                I always try to help out the local guys!
                Wow! Jonny, I will definitely be talking to you soon about that kit. That's a great price! I already have the MSD 6al2(two step) on my car, I wanted to go 150 shot, but for the price you can't beat that.
                96 Z28 Camaro M6
                2008 Silverado quad cab LTZ
                • #53
                  I need some info.
                  A lot of people mount the Ign. box on the drivers wheel well under the hood or below the intake elbow on that same wheel well. However, if you have deleted all your HVAC, like me, and installed a delete plate, put it right on that. Best spot ever imo. Reardless, keep it away from heat and definitely use the rubber mounts to reduce as much vibration as possible... heat and vibration do bad things to ignition modules! And make sure you install it to where your dials are easily accessible.. don't wanna have to unbolt a bunch of sh*t everytime you wanna mess with rev limiters or timing
                  96 Z28 Camaro M6
                  • #54
                    Some people have been suggesting the glove box for the IGN module?
                    Thoughts? Will it get too much heat in there?
                    1996 Base Model
                    +2 cylinder mod
                    • #55
                      I have heard that but I also heard the ignition modules throw out a lot of heat. I like Justin's idea of the HVAC spot.
                      • #56
                        My car still has all the HVAC, still will for a while.
                        I will be doing this setup as discretely as I can though.
                        1996 Base Model
                        +2 cylinder mod
                        • #57
                          There is no need to high an ignition box.
                          • #58
                            I have my window switch and retard box where the battery goes (my battery is in the back).... If your running an ls1 lid you could put it where your cai use to go, if not your probably going to have to stuff them inside the car.
                            • #59
                              I don't care about hiding the box, just figured I don't use my glove box and it'd be an easy place to change stuff on it.
                              I want to hide the nitrious stuff.
                              1996 Base Model
                              +2 cylinder mod
                              • #60
                                So I have the Mallory, ordered my kit from Jonny.
                                Now I need to figure out where to put everything.
                                I am thinking of putting solenoids under the PCM, I want to hide this setup as much as possible.
                                Can I put the Nozzle on the bottom of my intake elbow without losing out on anything?
                                Is it better to have it vertical? Horizontal? Facing the TB on an angle?
                                1996 Base Model
                                +2 cylinder mod
