Project: Huron Speed + 1999 Z28
    good to see someone properly routing the pcv
    At least I'm hoping it's right...this is my plan
    • A dual catch can set up would be nice.
      This is how im doing mine.
      Using vacuum from the turbo to help draw from the PCV system should really help the turbo drain also.
      • Added a turndown to the downpipe. In the future I may add more exhaust but for now this will work
          That should work just fine. Good point on the draining...I never thought of that before
          • all of the diagrams that guy did seem to work great I think you will be in good shape dual catch cans are def the way to go if possible, well unless you can afford a vacuum pump.
            • Originally posted by 1999Black_Z28 View Post
              The more pressure that crankcase has the harder its going to be for the oil to find its way back to the oil pan
              • and as long as you can get enough baffling to keep oil out of the intake tract you'll be good
                2000 Formula
                fixed slow junk
                • Pretty much done except for the tuning! Over the past few days I hooked up the wastegate, the BOV, and the catch can. Once that was done I went over everything to make sure all the connections were good and bolts were tight and the final thing I did was cut the bumper cover for airflow to the I/C. Today I installed the bumper cover, put the front tires on, and fired it up for the first time. Video's to follow...
                  In the meantime, here are the pictures of my progress:
                  p.s. don't mind all the bugs on the bumper cover...it hasn't been washed since last summer
                  • Look good Dave!
                    2000 Formula
                    fixed slow junk
                    • great job dave! cant wait to see and hear it in person. whens the tune planned? whos doing it? first track day? i wanna be there
                      - - 5.3/4L80e/T7875 - -
                      - Huron Speed Turbo Kit -
                      1998 Formula
                      • Originally posted by Formula Z View Post
                        Thanks Mike! I'm going to tune it myself hopefully within the next few weeks (as time permits). First track day is undecided but I will let you know.
                        • Comment
                          • Great job dude!
                            • looks like a very clean install Dave I'm excited for you, can't wait to see some numbers it should be a blast to drive.
                                Thanks Jeff! I'm excited to start driving this but I have a long ways to go before I start making real power. Right now the WG is referenced from the compressor and I have a 6lb spring in it. I'll be lucky to hit 4lbs in the intake but I want to take things slow until I get some more experience tuning with a turbo. After my initial tune I will probably buy a boost controller and keep playing with it the summer / fall with a few trips to the track but I don't expect great numbers this year.
                                Beyond that I need to swap out my 4.10 gears for something in the 3.50 range, swap out my LS7 clutch, and replace my leaking clutch slave cylinder this winter so hopefully I'm ready next spring
