Ok, so here goes! I have spent the last couple of years slowly buying the parts that I will need for the build of my 1987 IROC hard top. I have been seeing all if the amazing power numbers out of the LS based engines on here and tech. I have seen alot of cars with 500+ HP with heads, cam, and intake. But I just don't see the need to spend this kind of money when I think I can get the same or better results with a T-70 turbo setup on a basically stock motor.
So that is what I am going to do. I just ordered my turbo components today, they were the last on the long list of parts to buy.
I'm not sure if I want to lower the car yet, I want to see what it looks like (how it sits) with the motor in it. Since I bought the car 5-6 yrs. ago without a motor and trans. has been just sitting in storage. And I have been collecting parts ever since.
So this is the plan, and I will be documenting with pic.s as the build comes together.
The car just came out of the paint shop, now she has a fresh coat of arctic white with gold SS stripes (which it had from the factory), I will post pic.s later when I can get to the car.
The plan is to install the LM7 5.3 in the car then measure everything up for the hot side for the turbo. I am sure this will take some time but it is winter and I have a shop with most all of the equipment that will be needed.
For the motor I will be running an ls6 intake, ls1 cam, and a set of PSI bee hive springs. I'm not sure about what push rods to use yet. I will be using a ported slp oil pump, JP racing billet timing chain set, and ARP rod bolts.
As far as the fuel system goes I will be running twin in tank pumps in a 4th gen tank, -6 feed lines, and -8 return line, and aeromotive boost reference fuel pressure regulator, billet fuel rails, and 42# injectors. Not sure on what I will be doing for a filter yet.
I will be running all of the above into a T56 trans. with a spec 3+ clutch setup, custom drive shaft, and a moser 9" reared.
As far as the chassis goes I have a set of spohn sfc's and lca's. Like I said before, I'm not sure if I want to lower the car or not yet. I also have a set of C5 Z06 wheels 17-9.5 with 275/40/17 all the way around. On the brake side I'm going C5 Z06 front's, and ls rear's. I am thinking about a cage, maybe a 6 point. I just don't want any door bars.
I am really looking forward to this build, and I can't wait to be able to start getting my hands dirty. I would like to have it done by this spring. I would like to be able to run it on the power tour, and the lsx nationals. This will be a street car, not a drag car or a dyno queen. I am looking for 450-500rwhp in a fairly reliable combination. I think this should be doable.
