Will have an update today!
Sneak Peak: Superman09's 98-02 Turbo Kit
Grammar Nazi
- January 10th, 2006
- 6647
- Jonny
- under par
- Huron Speed
Grammar Nazi
- 6647
- Jonny
- under par
- Huron Speed
Here is the kit! Everything is in polished stainless steel! Complete with the specific couplers and t-bolt clamps. Couplers in future kits will come black. Brackets included are to directly bolt up the 4" core FMIC (which will also be included, not shown in pictures), and brackets to relocate your alternator! Enjoy the pics, the kit is beautiful!
Hot Side! 2.5" crossover with flange for 38mm Wastegate, 3" Downpipe with 3" v-band flange and flange for the 38mm wastegate to route back into the exhaust.
Cold Side! Set out how it routes with the specific made couplers! Flange for 50mm Blow-off valve on the pipe to Throttle Body as well!
Brackets
Grammar Nazi
- 6647
- Jonny
- under par
- Huron Speed
Tore engine down today! Waiting for parts to come in. Have the 6.0l heads and Turbo cam going in!
sweet! when do you plan on having it on the road (i didnt read thru all 3 pages of comments) and whats your horsepower goals?98 z28, m6, monster clutch, eibach pro kit, custom twin turbo setup, 317 heads, z06 valve springs, arp rod bolts, 512rwhp at 10lbs. cobra eater
Grammar Nazi
- 6647
- Jonny
- under par
- Huron Speed
It should be ready to go here less a trans and fuel system in the next few weeks. No specific power goals but should run very well. Power will depend on what trans the owner decides to run.Originally posted by Gaspo View Postsweet! when do you plan on having it on the road (i didnt read thru all 3 pages of comments) and whats your horsepower goals?sigpic
Interior Whore
- January 21st, 2008
- 6380
- fred
- 1996 Camaro z28
- U.P. and over you.
- united states coast guard
Grammar Nazi
- 6647
- Jonny
- under par
- Huron Speed
Grammar Nazi
- 6647
- Jonny
- under par
- Huron Speed
I think I have figure out a way to easily add an upgradeable option to this kit! It would be to run a 44mm v-banded wastegate and 4" downpipe.
Taking the hotside, I would fab up an adaptor flange off the 38mm WG flange that converts it to the 44mm WG flange. Then on the 4" downpipe, simply use a 44mm WG flange and move it down on the downpipe the distance of the adaptor flange so it will bolt right up!
lets put it into action, could you make one without the additional flange that routes the wastegate to the downpipe? Most companies actually recommend they be vented to the atmosphere.Doing less with more
Grammar Nazi
- 6647
- Jonny
- under par
- Huron Speed
I am going to say no, I don't want to do a bunch of versions, just 2 maybe where a second downpipe and an adaptor is all that's needed to upgrade. I will look into a block off for the downpipe flanges if one wants to vent to atmosphere and then all you'd have to do is flip the wastegate around and it will dump straight down!Originally posted by DETROITMUSCLE View Postlets put it into action, could you make one without the additional flange that routes the wastegate to the downpipe? Most companies actually recommend they be vented to the atmosphere.
