Sneak Peak: Superman09's 98-02 Turbo Kit
  • Sneak Peak: Superman09's 98-02 Turbo Kit
    Some of you may have known, others maybe not. I was going to turn my last 98 white Trans Am into a single turbo drag car. I started gathering some components and finally realized I was nuts. I parted with all of the parts except for some
    With the help of my friend Casey, we are now going forward with the kit on his car and it is starting to look pretty good, only a few more things to mock up!
    Kit features:
    Truck manifolds
    2.5" Crossover
    3" Downpipe
    MPT76Q turbo
    38mm WG, 50mm BOV
    4" FMIC
    3" Cold side piping
    custom FMIC bracket requiring zero cutting
    alternator relocation
    So far we have completed:
    Hot side bolted up and fitted
    Cold side fabbed and completed
    Engine yanked for a couple minor changes
    To Do:
    Change some engine components
    Drill pan and oil block for oil feed/return, run lines
    Re-Do Wastegate piping to route back into DP
    Mate DP to rest of exhaust
    Install Pusher fans
    Relocate Alternator
    Run vacuum lines
    Have complete system remade in polished 321 stainless
    Notes:
    Cold side will be made using 3 pipes to utilize as little silicone couplers as possible. Couplers used will be black on final product, this is just for mock up.
    Will have 1 pipe from turbo to intercooler. Will have 1 pipe from FMIC up to just under the fuse box. Then one other pipe from under fuse box up to the TB.
    Parts needed yet:
    LT1 Radiator Support
    Pusher fans
    Few engine components
    Air Filter
    Parts for sale:
    TSP 5.3l stage 2.5 Heads complete with dual gold springs (100 miles on all)
    Custom Pred Z "El Toro" Cam. 230/230
    TSP 7.400 chromoly pushrods
    Here are some progress pictures!
    Lookin' good, so far. Were you going to cut some of that fascia & install a grill, to let a little more air into that inter-cooler?
      Yes, he wants to run the 6LE front grill
        Looks like sex. Remember in the book Maximum Boost is says be careful driving in the rain because the sudden on set of boost can cause you to look control. =p
        Originally posted by Yoshi94
          looks awesome man! i'm very jelous. you are a lot farther than me in your project. how much boost do you plan on running? whats your hp goals? are you using meth injection?
            8-10 psi, no meth, looking for 550-600 rwhp Thanks!
              awesome! thats about my goals too. where did you buy the intercooler? i need to buy and fab up a whole cold side
                Intercooler is through my supplier. If you in need of one, shoot me a PM! I can also fab you up the bracket as well!
                  looks freakin sick Jonny I would expect nothing less from you though. Can't wait to see the finished product.
                    Looks awesome Jonny! Why the heck hasnt Casey found his way over to this site yet?
                      nice work !
                        Thanks Jeff! I'd like to get one of these on your rig also!
                          Thanks, he's more into the grudge crowd.... not much of a post whore
                            say the word and I'll start disassembly
