My APS TT Install Thread
  • #91
    Is that the stock 99 Battery plate and coolant reservoir?
    I have the crappy all plastic bottle, and battery plate; and they just keep snapping. i think i have been through 3-4 reservoir bottles.
    If it after market where did you get it?
    Thanks
    1996 Pontiac Firebird - Blue/Green Chameleon - 3.8L V6 (231ci)
    Totaled & Declared Dead: 08/07/2001 - Rebuilt & Reborn: 08/21/2002
    • #92
      Thanks
      Hope, the kit came with a new battery plate and stainless steel reservoir. Just uses the stock neck on it. Check today pics for one of the reservoir.
      My Toys: Hugger Orange 1999 Z28 6-Spd Twin Turbo
      1937 Chevy Extended Cab Pick-up (One of a kind)
      Future Toy: Orange Ultima GTR or SLC
      • #93
        Updates from Tuesday 04Sep07
        Thanks everyone. Made more progress last night but ran into some things that slowed me down.
        Had to re-route some wiring that was out of place when the k-member went in on the RH side. And found one of the turbo coolant lines also on the wrong side of the k-member on the LH side. Corrected those (which took a while due to no space to move a wrench!), and moved on to the motor mount bolts. The RH side went in nice and easy. LH side was a Beeeyotch!!!! Had to phone a friend and Dave came to the rescue again. While waiting for Dave I reinstalled the cooling fans. Once Dave arrived it took the both of us to wrestle that bolt into place. Me reefing on the prybar moving the BMR motor mount, and Dave pushing on the bolt to slide it in. I was curled up under the car using my knees on the brake rotor for leverage. Whew! Don't need to workout this week. I am sore from all of this wrenching! I also bent my prybar in the process. I am like a mini hulk! Next item was to tighten down the starter.
        Once that debacle was behind me I tightened down the manifolds to the heads and rechecked clearances under the car. Then I finally started installing the turbo charge pipes. Got the LH side set into place. Still need to finish the brake lines with the BMR K-Member install as the LH charge pipe bolts to the brake line bracket.
        Also had another friend Chris (Irocss85 from LS1tech) stop by at the end of the night and finally got my fuel sending unit out so I can install my racetronix pump. Thanks man! That was a pain and just needed even more persuasion than we were already giving it. aka a bigger hammer!
        Also snapped a pic of the radiator overflow bottle. Just looks too nice not to show off.
        • #94
          More pics from Tuesday.
          • #95
            Getting there... It is getting to the point you can't sleep at night yet?
            I like the Hugger Calipers!
            • #96
              Ha ha. No, when its time to go to sleep I crash hard. All this working is draining. And thanks, the calipers have been painted since 2000. I think they held up pretty well. They look sweet behind the new wheels. Really contrast nicely. Gonna have to paint the new monsters soon...... That is another weekend project after this turbo stuff is done.
              • #97
                Looks awesome!
                • #98
                  woot more progress..lets make a deal..
                  When everything is fine and dandy and u go for the first test drive..ill drive out to you..and you let me drive it..in exchange..ill give you a bag of M&M's..good deal right?..lets negotiate
                  • #99
                    Updates from Wednesday 05Sep07
                    OK last night was another long night in the garage. Some good and some bad news.
                    I removed the fuel bucket so it would dry and I can swap out my fuel pump.
                    Got all of the intake system plumbed on the car. What a chore that was!! I seriously think they designed those rubber intake hoses as a sick joke. Took me a while to wrestle each one on. And then the trick was tightening the clamp so it was actually on the neck and did not slide off the neck as you tightened it....... Anyway after a lot of finaggling and some explecatives they are on the car. Installed the stainless intake pipes that bolt to the roll bar. Not too bad except for when I started to cross thread one of the bolts. DOH, out with the tap to clean the threads. Then installed the air filters. Those fit fine on a Firebird. But the Camaro's have our fog lights right there and discovered the filter did not want to go on very easily. I managed to find an angle for the filter that sort of works around the foglights. Hopefully those will clear when I put the fascia back on the car.... Next were the blowoff valves. Very easy and no problems there. It is starting to look very good!
                    Got the top end of the intake all installed. I think this was another joke as there is NO way to get those hoses on there in the limited space. Intercooler does not move nor does the intake. I had to remove the throttle body, loosely fit all hoses, MAF, etc and then finagle the whole thing back into place. While not impossible, not as straight forward as the install manual would have you believe.
                    Ran into an issue with finishing of the BMR K-Member install. They call for bending and re-routing the brake lines a little. When I followed the instructions and picture they provide, my flexible brake hoses are stretched way too tight. There is not enough slack to steer the car. I know this is not right and am wondering what anyone else with a tubular k-member did with their lines. I have a few ideas to try that I just brainstormed this morning such as flipping that bracket to move the attachment down and give me some more slack for the flexible line. I am a brake engineer and the tightness of those hoses worried me last night. Let me know what others have done there.
                    Also pulled off my AIR hoses as I don't think I am going to hook that up after this install. The manifolds have provisions for them but they are for 00-02 vehicles and mine is a 99. The attachments are 90 degrees off and I would have to rotate and rebend my lines to get them to line up correctly. No thanks. Easier to just take them off. I will also have to remove that EGR mechanism from the RH head too. And get a block off for the intake portion of that EGR circuit.
                    • That looks sweet! I want a sound clip!
                      Side note: These guys do a lot of APS installs if you want to bounce ideas off them. http://www.exoticperformanceplus.com/projectCars.php
                      88' Trans Am 350 TPI
                      • Originally posted by scholtmj View Post
                        Thanks. I will do my best to get a video when we fire it up. Yeah I post on LS1tech too and was hoping EPP would chime in on my questions. I may just call them though. Thanks.
                        • good work..how much would this cost if you went to a shop and have them install it for you?
                          • Originally posted by DeLaRosa25 View Post
                            Nobody will be driving this but me for a while. I have driven 500hp before and know how to handle it. Not sure about anyone else as it is a handful. Even so I am sure I will still pull some stupid moves. But at least its my car.
                            No clue. EPP just installed one on a customers car so they could probably quote a price. And probably a lot more than I would want to pay. Especially when I can do it myself!
                            • Originally posted by Hugger Z View Post
                              Mmmm...you strong like ox...lol...
                              BTW, this is a great thread.
                              The pics, the descriptions, the problems, the successes, this is a textbook do-it-yourself thread IMHO.
                              for turbos!
