Originally posted by dirtybird
View Post
cylinder head porting?
I wasnt looking for a valve job either until i disassembled the engine and found i needed one.-Joel
95% of the heads with 50K+ miles on them will need a valve job. At bare minimum the valve seats should be cleaned with scotch brite and the valves ground IMOOriginally posted by JoeliusZ28 View PostI wasnt looking for a valve job either until i disassembled the engine and found i needed one.
X2Originally posted by c0ncEpT View Post95% of the heads with 50K+ miles on them will need a valve job. At bare minimum the valve seats should be cleaned with scotch brite and the valves ground IMO
Also eric bradby is a pretty dang good porter, does alot of the lt stuff. But as Joel mentioned the big 2 for ported factory castings is le and ai
Mine had worn guides on the intake side, everything else seemed good but i had the full job done on intake side.-Joel
Jeeze i would hope so! You arent even utilizing the capacity of the stock heads with a stock cam!Originally posted by mcalus View PostAnd while you're that far in there you should just put in a new bump stick
Youd probably be better off looking for a stamped part number-Joel
