Header install goes to Sh%t!
    Take them out and reuse your stock gaskets. I have never even heard of an MLS manifold gasket leaking.
    Originally posted by doubleaction View Post
    im just afraid i will install the motor mounts and its not going to fix the issue...you guys really think the mounts will fix the header issue? I tried taking a huge pry bar and prying the engine a little and it didnt seem to move the header much.
    Yes it will more than likely fix the issue. If not send them back to hooker and buy some Pacesetters...
      do you have any pics? That might help to diagnose the problem/evaluate whether or not mounts will fix it.
        im taking pics monday when i take it to my friends shop.
        2000 T/A
          Is it the header colloctor or the y pipe. I had problems with the y hitting a cross floor structure. Y should normally have a flat spot there mine doesn't. I definately would do motor mounts or cutting re welding headers before doing anything to the floor. One suggestion is to loosen header and see how much shift in bolt holes you get.
            Originally posted by Bad_Z28 View Post
            Make sure your headers are the correct headers aswell before going and doing all this work.
            That's what I was going to suggest.
              i have never had them hit the body. I have had some hit the corner of the K-member though.
              what trans mount do you have?
                That was my first thought as well...
