Ok so i tried to install the hooker longtubes i bought and the drivers side manifold its touching the floorboard. What can i do to fix this? I cant even get a clamp in there. Someone told me that the passenger side motor mount could be faulty which is causing this. I checked the mount and didn't notice anything wrong.
Header install goes to Sh%t!
Option 1: BFH to the floorboard
Option 2: cut and re-weld primary tubes on the headers so that they're angled lower or so that the collectors are lower
Option 3: relocate motor mounts
#1 would be the easiest but not for the faint of heart. There's probably other options I'm not thinking of though.
Used to own a Firebird.
None of those options sound good to me. Even if you BFH or cut and re-angle its going to bang on the floor boards hard under any kind of acceleration. You need new motor mounts period. Buy some polys and be done with it.
yep must be the motor mounts, I 've never heard of hookers doing that on an LS1.Doing less with more
Poly ones are the best, but can be considered a little harsh for people worried about a soft and cushy ride. Your gonna feel your engine more through the frame if that makes any sense. The motor mounts are not to difficult to do, will probably take 2 hours taking your time. Make sure your headers are the correct headers aswell before going and doing all this work.sigpic1994 Camaro Z28 83K M6, CAI, AFR 190cc, 11.6:1, Hooker headers, Hooker ORY, Mangnaflow exhaust, AI 230/238, 1.6 RR, B&M Short throw, Hays clutch, 4.10 gear.
i just want something that will last a while, and wont be too expensive.Originally posted by Bad_Z28 View PostPoly ones are the best, but can be considered a little harsh for people worried about a soft and cushy ride. Your gonna feel your engine more through the frame if that makes any sense. The motor mounts are not to difficult to do, will probably take 2 hours taking your time. Make sure your headers are the correct headers aswell before going and doing all this work.2000 T/A
I really don't think the poly ones will cost very much more than the stockers, and both will last a very long time.Originally posted by doubleaction View Posti just want something that will last a while, and wont be too expensive.sigpic1994 Camaro Z28 83K M6, CAI, AFR 190cc, 11.6:1, Hooker headers, Hooker ORY, Mangnaflow exhaust, AI 230/238, 1.6 RR, B&M Short throw, Hays clutch, 4.10 gear.
I agree go with the poly mounts, they are like $60 from CS3 and they just go right into your stock clamshells, you just have to drill out the rivets. When I installed mine I never noticed any added vibration and they keep the motor from flexing so much.Doing less with more
im just afraid i will install the motor mounts and its not going to fix the issue...you guys really think the mounts will fix the header issue? I tried taking a huge pry bar and prying the engine a little and it didnt seem to move the header much.Originally posted by DETROITMUSCLE View PostI agree go with the poly mounts, they are like $60 from CS3 and they just go right into your stock clamshells, you just have to drill out the rivets. When I installed mine I never noticed any added vibration and they keep the motor from flexing so much.2000 T/A
