maybe there is corrosion in those wires away from where they were repaired
I give up....Cant figure out starting issue
I am going to check FP and spark, Ive had a couple peopole locally suggest TPS, But anytime ive ever had tps issues with other vehicles, it has thrown a check engine light, which I have not had happen on the camaro. I have, just to be sure, scanned the car with my scan tool and sure enough, NO CODES PRESENT....SOOOOO. If I check the FP and checks out good, and I check the spark and if it checks out good, then where do I turn?
Again, the VATS system has already been bypassed as I was thinking that was my issue, but it made no difference. Ive also had someone suggest the ECM.
is there a diagram somewhere showing where all the grounds are in the system? or is it a process of ripping the whole car apart and replacing all the harnesses? If so, the car will be for sale. I dont have time, money, or paitence for all that mess
Originally posted by nascarnate326 View PostI bought this and it solved my VATS issues:
http://www.ebay.com/itm/GM-VATS-or-P...e68061&vxp=mtr
You can also have it tuned out.sigpic
I already know what yoir problem is... very very weak fuel pump.
Had the exact same thing happen with my 93 z28 a few years back.
Would drive just fine. But above 5k rpm it would act like a pissed
Off horse.. buck, backfire, no power. Let off the gas to a lower
Rpm and it would be fine.
My pump was going out slowly. By the time a changed it I had
16psi at the rail and it would instantly be gone...
Running. I had 8 psi. But 4 months prior to that I checked it
And it was normal. So I ruled it out.once I changed that pump.
My car what a whole new animal. Hit the key it fired right up.
Just the slightest touch pn the gas and it was moving.
I took that car way past suggested crank rpm without even
So much as a hicup.
Try your fuel pump. And on the slight chance that's not it
Check the coil to opti plug wire.
Mine also acted the same way. That wire was bad.
If that checks out. Time for an opti.
Originally posted by 9302z28SS View PostI already know what yoir problem is... very very weak fuel pump.
So much as a hicup.
I was busy doing yard work all weekend and didnt get a chance to check the car out, I did talk to an old mechanic that used to work for my dad years ago and he recalls all the issues with the optis and recommended I check that out as well. How hard is it to get to the opti? and if it does in fact need a new one, ( I was told it had a new one when I bought it) is a stock replacement fine or is there a aftermarket solution that is better than the next? and what do they cost?
Just gotta remove the water pump and crank pulley. There are alternate ignition timing things but they're expensive as hell. I've heard to go either msd or oem, and NOT accel. Just remember to
Put the spline drive back on the water pump/opti. this is also a good time to do a coolant flush
Sent from my car phone using shiftatalk 2sigpic
Originally posted by mazakman View PostDid you get it going yet?
I stopped by a shop today on my way home from work but I cant afford $80 an hour for labor
I wish there were people around my area that had more experience with these LT1's but unfortunately there's not
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
Did you even check this for spark? Jeez its so easy to check. Pull the wire off, then put a plug in it, hold it to a piece of metal, crank check for spark. (Don't hold the plug you will get poked with like 40000v)
Now before I go on to help you, you need to do two things. You need to check fuel/spark. You said fuel primed. To what exactly? Was it in specs?
I need to know if its sparking.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thoseOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Originally posted by Fox Slaughter View PostDid you even check this for spark? Jeez its so easy to check. Pull the wire off, then put a plug in it, hold it to a piece of metal, crank check for spark. (Don't hold the plug you will get poked with like 40000v)
I GOT IT FIXED!!!!!!!!!!!
Its been over a year but I finally figured out why my camaro had the starting issue! it was blind luck. fuel pressure was good, battery was good I was messing with it one day and noticed when I turned the key to the ON pos. the dash didnt light up and the pump didnt prime. i grabbed a hold of the key and cylinder and gave it shake and everything powered on, turned to the start pos. and it lit right up! ALL THIS TIME AND IT WAS A $35 IGNITION SWITCH!!!! ITS FIXED AND RUNNING!!!!!
I had guys telling me " ehh, just sell it for whatever you can get out of it and cut your losses" WTF!
nice , its the darnedest things that just fail or act up. Glad its working did you replace the ignition switch yet?'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
Originally posted by Gregs_gsxr View Postnice , its the darnedest things that just fail or act up. Glad its working did you replace the ignition switch yet?
