Guys, Please help! IM LOST. last summer I had different issues with my ignition, the key stuck, the car dosent start correctly etc etc.
So, I took the column apart, tightened up the bolts that were (so i thought) making it "wobbily" didnt seem to help. I cut the VATS wires from the key cylinder and used resistors to bypass the VATS. I slightly adjusted the ignition switch on the column. the car still does not start as it should. the car will just crank and crank, turn the key to "off" and back to "on" wait for dash lights to go out after pump primes, crank crank crank...it will do this any number of times and sometimes, after any number of attempts, it will start, sometimes when it starts, it runs fine, once in a while it will act as though it is running on half the cylinders, when i does that, i shut it off and try to fire it up again, go thru the cranking again and it will eventually start and run fine again. I am completely baffled. Im ready to unload this thing and buy another darn motorcycle. and i really dont want to. i love this car but here it is july and i havent drove the car once. where do I start? what do I look for? PLEASE!!! HELLLPP!!!
Kelley
Kelley
