tuners please step in
    For the normal version - search on the HPTuners site.
    There is a way to run the WB02 5v back through the EGR circuit - and it works well.
    Basically - reenable the EGR, zero out all the tables and then you have to edit the egr pid to show afr.
    2000 Formula
    fixed slow junk
      Re: tuners please step in
      Thanks alot that awsome info. i will get on it.
      Sent from my HTC6435LVW using Tapatalk 2
        Yep i did the same thing on my car with the ac pressure sensor/value
          ok with alittle help iv come up with this. I know it still not right and im still trying to figure out injector flow rate to but im learning. I would be greatful for any
          help.
          buick regal 5.3l 4l80e 76mm turbo 3.hpt
            Another way to go about it Ken for additional help would be hptuners web forum also.
              my software is still locked, wish I take a look and help out
                Thats where i got the help so far is ls1tech and hptuners forums.
                  Have you tryed downloading the new demo software on the home page. before i got this it was letting me view tunes. I also have a old key with no credits i could pm you. it should un lock it.
                    If you could PM me an old key that would be great, not trying to tune any vehicles. I just want to get a feel for the software really, and being able to modify and save a tune might be beneficial to you. I'm still up in the air on HPtuners or EFIlive as I have a few vehicles that need to be done.
                      No problem. the key i can send will only let you view and save. Theres no credits.
                        I'm in, but it says I don't have the correct licensing for the file. No biggy, I can see what you have and offer suggestions.
                        Under the fuel/general tab you have "Injector Flow Rate vs KPA". Injector flow rate isn't a constant like in the old setups. From what I see it doesn't factor boost into the table. Do you have a boost reference fuel pressure regulator?
                          Yes and i have no idea how to setup for those injectors.
                            http://ls1tuningguide.com/files/free...torscaling.htm
                            ^use that spreadsheet Ken.
                            2000 Formula
                            fixed slow junk
                              thanks jeremy
                                thanks jeremy
                                No problem - it should get you in the ball park
                                2000 Formula
                                fixed slow junk
