Friend of mine ran an msd on his camaro before it broke. It lasted about a year, I don't know the mileage. I do not know if mine is the original or not but I have put 40k on the car since I have had it and it is a delco unit.
Opti-spark msd vs gm
if your not revving past 7K you dont need a 24X... its still nice but youll be perfectly fine with an opti. my car should make close to 700RWHP and im running an opti...1997 Camaro SS convertible #594-Gone but never forgotten
Reliability and tunabilityOriginally posted by 1fstss View Postif your not revving past 7K you dont need a 24X... its still nice but youll be perfectly fine with an opti. my car should make close to 700RWHP and im running an opti...2015 Silverado
Chandler Motorsports opti can be had for under $100 making the 24x conversion that much more overkill.- Brian Meissen
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
Have you changed plugs and wires, thats easier than the opti and could be the issue.
EDIT: I had intermittant miss and finally changed opti which didn't fix it, sold opti for 20 bucks and think its still running.Last edited by 98blackbeauty; October 23rd, 2012, 06:44 PM.sigpic
at least 3x the cost of a typical opti replacement. I think it will be one of the best things I'll ever do to my car though. I believe that the difference in these systems is THE biggest reason for the LS1s good reputation and resale in comparison to the LT1. Had the LT1 been 24x from the factory, we would have seen a MUCH bigger aftermarket.Originally posted by hoogiesngrinderz View Post24x will cost you a LOT more, no matter how Dutch you are...Last edited by JoeliusZ28; October 23rd, 2012, 07:29 PM.-Joel
Originally posted by JoeliusZ28 View Postat least 3x the cost of a typical opti replacement. I think it will be one of the best things I'll ever do to my car though. I believe that the difference in these systems is THE biggest reason for the LS1s good reputation and resale in comparison to the LT1. Had the LT1 been 24x from the factory, we would have seen a MUCH bigger aftermarket.
ignition is the only reason I did/am considering an LS swap. Its just a far superior system.1998 Chevrolet Camaro Z28 - 6 Speed
I put new delco plugs in it 10,000 miles ago and new msd wires. I'd like to think that's not my issue but I'm not ruling it out. I hate trying to diagnose intermittent issues. But I hate throwing parts at it till its fixed even worse.Originally posted by Plum Nuts View PostHave you changed plugs and wires, thats easier than the opti and could be the issue.
