Fuel additive(storage)
    Thanks for the info guys.
    I think I'm gonna leave it empty and hook it up to a tender and put the cover on it. Thanks again
      Yep, battery tender for me.
      Leaving the tank empty leaves air space, which can equal humidity, and moisture (rust) on the tank walls. The advice I've always seen is to fill it.
      Though I can understand if your first stop in the spring is at the race track, not wanting a tank of 6 month old fuel.
        I heard this too, to me it seems easier to drive it around a few days and burn up the old gas before going to the track than risk rust in the tank.
          Does stabil help extend the shelf life of the fuel and prevent it from gumming up carbs? Didn't use anything when I put the bike away last year and it ran like absolute shit the first few times I started it after the winter even with fresh gas. Don't want to have to do a carb service any sooner than absolutely necessary.
            http://www.goldeagle.com/product/sta...60-performance
              That stabil 360 stuff looks really similar to the BG product we sell at the dealer. It's called BG ethanol defender. I called BS on the BG guy right to his face when he was training us on this new stuff - he had a demo where he took standard gasoline, added dye that only absorbed into the water that's stored by the ethanol, and showed it all to us so we could see the separation, like what's in the video on the link I just gave. After he poured in the BG ethanol stuff, it scattered the water/ethanol mixture so that the ethanol doesn't set on the bottom of the tank. He said that when the ethanol and water is floating in the gasoline, you don't get quite as bad of corrosion inside the tank, and you'll get better startup quality. The other bottle he had was a corrosion inhibitor that he said would keep the entire tank protected like what the stabil 360 stuff says.
              Me personally, I just park it. Charge the battery once in a while. I don't run it until it's warm out, because if I don't want to help create any additional moisture inside the crankcase that I'm not going to get burned out just idling the car.
              91 Firebird 305 TBI
                Thanks for the link.
                  My storage routine is to take it for a cruise (usually pick up lunch)...fill the tank while out...then I bring it home (only 1 mile drive from station) and clean it up...back it up into the garage, change the oil and filter...throw on the battery tender, and cover it up.
                  I'll be doing this next Fri
