Clean out the garage which means may trips to the scrap yard. Change the engine/trans/diff fluid in the M3 as well as put on new wheels/tires/shocks/swaybar/strut bar and install the datalogger. Replace the drivers floor in the Camaro and put the fuel tank and rear axle back in it, install the Watts link and decoupled torque arm, paint the wheels.
So what are your spring projects?
aka Purple94Z28
- May 1st, 2009
- 1858
- Nick Kerns
- 1999 BBM z28 Camaro
- Saginaw Michigan
- New Car Sales Consultant
Would like to finish my ls1 brake swap need to gather rotors and a good set of pads...also thought about having the calipers powdered red. Need to find a reputable exhaust shop to tidy up my I-pipe or replace it. And I would like to get a MGW shifter...otherwise I just want to drive it!!1999 z28 Bright Blue Metallic 1 of 10
Oh, good reminder - I have to do window motors too. I have one, but will get another and just swap out both. Want to do the sound insulation, window tint, and motors while the panels are off.
Oh, yeah - hopefully tint as well!
weddings ruin everythingOriginally posted by MP81 View PostBrakes, maybe
Probably not a lot, considering upcoming (and non-finalized) wedding costs.
My List
I need to lower the car so springs, shocks/struts
EGR and AIR Delete
Brakes and rotors paint calipers while im at it
Peel off the Plasti-dip off for the CETA mod and paint it
Remove slim tubes that replaced the Cat's by previous owner with stocks
Wanted to replace rearend (from a 2.73 want atleast the 3.23) so I'll be looking for the whole rearend which may be cheaper than having the ring and pinion swap
I still need to see what else I can do..Lol!sigpic
02 Camaro SS LE
Stock for now
15 Silverado Crew
2/3 Drop/22" OEM wheels/Magnacharged/Corsa/Tuned
11 Chevy Tahoe
Stock
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Greenville, MI
- Die Maker
I was told my IROC would be done with paint sometime in March, we'll see if that happens.
Still on the list:
Convertible top
Address some interior issues
Swap LS1 brakes to 14" fronts and 13" rears
Swap in the new cam and 1.6 roller rockers
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
find a cheap 350 and get my 72 running or ive threatend it with tearing it apart91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
00 Tahoe Z71........Stock
