Here is a vid of what is going on. Just a quick description: Car fires right up, idles fine for a bit, maybe 30seconds-1minute. Then it starts getting erratic and the fuel begins to climb. It usually almost hits about 50psi then dies, from what i think is flood related. But I am stumped, and I need some help.
Note: I just removed the EGR system completely, and have yet been able to drive it since! It has to be related. I can't drive it ten feet without it dying. Then it won't start for a while afterwards. Rechecked all the block off plates today and resealed them, they are sealed for sure. Meissen Sr. mentioned the plates might be leaking causing the fuel to try and compensate for the difference. But that doesn't seem to be the case. The car was just started at the beginning of this vid.
My Chiltons manual says a faulty EGR will cause the car to stall at low r's and run like crap down low. Will removal do the same thing?!? Everyone said this wouldn't affect the car at all.
