depending on my compression test, i might be throwing out the ls1 and upgrading. what would i be better off with? a 5.3 or 6.0 truck motor? dont have the money for an ls2. which motor is better for boost? which one is more reliable/holds more boost/hp? i can put my 317 heads and stock intake on it.
5.3 or 6.0?
5.3 or 6.0?
98 z28, m6, monster clutch, eibach pro kit, custom twin turbo setup, 317 heads, z06 valve springs, arp rod bolts, 512rwhp at 10lbs. cobra eater -
oh, compression test wont tell me anything?Originally posted by 1BADAIR View Postleak down test. not compression
how much boost can it hold? what kinda power can i get out of it safely?Originally posted by c0ncEpT View Post317's on a 5.3 get you down to like 8.1:1 SCR. The car will be a roach out of boost but would be able to take quite a bit of boost.98 z28, m6, monster clutch, eibach pro kit, custom twin turbo setup, 317 heads, z06 valve springs, arp rod bolts, 512rwhp at 10lbs. cobra eater
ok thanks!Originally posted by sman View PostI would say you probably cant go wrong either way, but a 5.3 with 317s should take the most boost. If you look at 6.0s stay away from the lq9 thats gonna have a lot higher compression that what your looking for.98 z28, m6, monster clutch, eibach pro kit, custom twin turbo setup, 317 heads, z06 valve springs, arp rod bolts, 512rwhp at 10lbs. cobra eater
I'd get whatever is cheaper, most likely you'll find an iron 5.3 so the block strength is there for either motor. What size are your turbos?Doing less with more
Either one is fine. The 5.3 is a little strong of a block just because of the amount of cylinder wall in there still. When I was looking for an iron block I happened to find my 5.3 the day I cracked my alum block so I went with that and had my car running again in 5-7 days
lol
1998 Camaro SS Bullseye Turbo
Lurker- August 27th, 2008
- 452
- Anthony Z
- 1989 Trans Am GTa V8
- Muskegon, MI
- mechanic/quick lube tech
- Greenville, MI
- Die Maker
6.0 too common? 5.3 was the most mass produced genIII engine
I picked mine up for $212 on ebay with 44k miles. I had to pay a few hundred to ship it, but still.
How many 5.3 ls powered cars on the site?Originally posted by hoogiesngrinderz View Post6.0 too common? 5.3 was the most mass produced genIII engine
Only one that I know of was Sman and he moved onto a 6.0 I believe.
6.0 is a very common swap into an fbody. 5.3 are making their way into every thing but most people figure for the extra hundred bucks go with the 6.0.1998 Chevrolet Camaro Z28 - 6 Speed
