View Post
West Side Tuner
Shift points can be a common problems with tuning. When Vector tuned mine with just headers and 3.73s my shift points were botched. It was hitting off the rev limiter. I called them about it and they said it was probably due to bad transmission... Found out later it was the tune and had it fixed from a different source.
When Vector tuned my oil burning cam engine the shift points were spot on with no changes to the stock trans.
On this new tune I'm not sure as obviously the trans was broken. However, Steve did mention he may not have the shift points right due to the cold weather. Coulda just been cause 3rd was bad so it threw him off.
Liz had a lot of issues with her trans and thermostat. She couldn't go to Woodward without replacing her thermostat halfway there and adding coolant.Originally posted by WMCCjames View PostReally? I don't recall...who was unhappy with him?- Brian Meissen
Kyle A. fixed that - there was air in the systemOriginally posted by meissen View PostLiz had a lot of issues with her trans and thermostat. She couldn't go to Woodward without replacing her thermostat halfway there and adding coolant.
her problem with TJ was with the tuning for her trans and the 4_00 stall that she has in it2000 Trans Am l 1967 Firebird
i didnt read thru all 4 pages of this thread, but just call tj and talk to him. it might take a while for him to return your call, but he knows that he's doing. he tuned my car at first with eztuners or something i think, then when i went to speed density tune and he did it with HP tuners. i started my car up today (its about 15 degrees) and it started right up and idles fine. in the hottest day of the summer at 100 degrees it does the same thing. cant complain about the tune at all. i dont ask questions about what my knock count and injector pulse etc are at because i dont know whats good or bad. he told me my duty cycle is low, which i know is good since i'm using 83lb/hr injectors. he dyno tuned it, then took it out on the street and makes sure it drives good. my wideband wasnt working, so he hooked his up and tuned it with that.98 z28, m6, monster clutch, eibach pro kit, custom twin turbo setup, 317 heads, z06 valve springs, arp rod bolts, 512rwhp at 10lbs. cobra eater
My bad - I thought the thermostat was related to the tune's settings on when the thermo should open. The trans issue was definitely a result of TJ's tune, th ough.- Brian Meissen
Liz did have a problem in the tune with the t stat cat remember 100% but it wasn't allowing the fans to come on at the right temp or something like that. Also had it tuned for a different degree t stat too.sigpic
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
Mark, sorry you misunderstood my point. I was not defending them, but giving general statements based on your post. My point was to get help to resolve your problem from tuner and get advise. As I said hope new tuner works out good for you.Originally posted by xDetroitMetalx View PostSee, now you're defending them but on the wrong point. You're also inserting details in the story that you assume happened. I had no chance to ever know if there was an issue with the trans, if there was one, prior to dropping it off. My best guess is that the clutches burnt up on the dyno due to starvation. The transmission was rebuilt, brand new, along with the torque converter, it was driven straight to Vector. I also did communicate verbally and in writing with them that it MAY be low on fluid and they said it would be looked at. With that even said I already openly admit that the trans was 100% my fault and not theirs, it's something that I should have made sure was taken care of prior to drop off.
When I spoke to Steve on the phone I explained what happened with the trans and told him myself it's nothing that I blame them for. However, what I am complaining about is the lack of detailed information that I would like to know. I have to live with this car, not them. If it was tuned in Open Loop then that should have been something told to me when I picked it up. I'm sorry if I am someone that wants to know specifics about work done to my car instead of just throwing money at it, getting it done and walking away. This car is my money blood sweat and tears, I did all the work with this biuld but bulid the engine as I wanted one set of hands working on it, and the trans as I don't have the proper tools and know how and the tune as I don't have the tools or know how. I know where my limits are when working on a car, thus I hand it to professionals and I'm disappointed if I don't get the work or service I feel I deserve when I fork over hard earned money.
I did not know Steve was a member here but honestly at this point it doesn't matter. I'm a nice person and I work well with people, sadly I do not think they have any urgency to work with me or trouble shoot the issues that I believe involve them. I already decided before posting this thread that I am going somewhere else, I'm just not happy with their services and that's fine. As I said, I know they produce good work and I'm not afraid to drive the car around at this point. However, I need some questions answered before I'm 100% comfortable with it. Hopefully another tuner can give me the answers I seek.sigpic
Originally posted by Darren View PostLiz did have a problem in the tune with the t stat cat remember 100% but it wasn't allowing the fans to come on at the right temp or something like that. Also had it tuned for a different degree t stat too.
Was he made aware of all of that?
Thats the most basic part of tuning.
I watched him Tune David's LS3 Trans Am and he did an awesome job. Hope I have a car that runs that good some day.1998 Chevrolet Camaro Z28 - 6 Speed
i wanna ls3 swap in my car..Originally posted by nascarnate326 View PostWas he made aware of all of that?
I watched him Tune David's LS3 Trans Am and he did an awesome job. Hope I have a car that runs that good some day.98 z28, m6, monster clutch, eibach pro kit, custom twin turbo setup, 317 heads, z06 valve springs, arp rod bolts, 512rwhp at 10lbs. cobra eater
lol they told you, you can't make 400rwhp on a 383? I made over 500 to the wheels on a 385 on MOTOR on 93 octane.
Steve tuned my car, he had it for over a week. I was told to come and get it, and that he would do a nitrous tune when I brought it back. After paying Steve for the tune, I could never get ahold of him again, through PM's, phone call's, or anything. Goodluck.
Steve did clean up the previous tune which was garbage, and he pointed out some other things to me as well. But once I realized some things with the tune that I wasn't happy with, and that I wanted to bring it back to do the nitrous tune, I never heard from him.Joe - ATM SQUADAt the shop, watching them build my car.
Post Whore
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
Nice #'s! Was he the one who got those numbers from the 385, or did you have a final tune on it done somewhere else? Was that the motor combo you posted on here the other day or something different? Those are very impressive numbers for all motor on 93.Originally posted by PWND3r View Postlol they told you, you can't make 400rwhp on a 383? I made over 500 to the wheels on a 385 on MOTOR on 93 octane.
Steve did the tune, we changed some things but not much. I would've liked to have seen what it would've done on the 225.Originally posted by birdie2000 View PostNice #'s! Was he the one who got those numbers from the 385, or did you have a final tune on it done somewhere else? Was that the motor combo you posted on here the other day or something different? Those are very impressive numbers for all motor on 93.
Steve was great to deal with, and knew what he was doing but the follow-through would've made things a lot better.Joe - ATM SQUADAt the shop, watching them build my car.
