I don't remember, I think $220? There are 2 rev limiters. A low RPM and high RPM. The high RPM is just your typical rev limiter. I have my low RPM set up to where I push my clutch in and i can put the pedal to the floor and it won't go over my set RPM. Makes launching a breeze. It also incorporates the multiple spark feature like other MSD boxes.
2015 Silverado
what does the multiple spark feature do?
It's hooked to the clutch switch and a momentary. I push in the clutch, hold the button and floor it and it goes to where the 2 step is set. Release the clutch or button and it goes to the pcm rev limiter.
The button is there so it doesn't backfire on the shift. I never lift for a shift....but the 2 step isn't cutting spark to assist me.
what is a "momentary"? why does it need to cut spark? i'd like to see a video of it in action. so you push the button to hit the 2 step on launch, and then let the clutch out, take off, and as long as the button is still down, you dont have to lift to shift?
