i just changed my oil about a week ago, now the sensor on the pan is leaking so i went to swap that out and as expected got a little oil everywhere
but anyways it was black like it hated been changed in years. didnt smell like gas nor was it shiny as if it had gas or coolant in it just black. this cant be good can it
black oil already?
Interior Whore
- January 21st, 2008
- 6380
- fred
- 1996 Camaro z28
- U.P. and over you.
- united states coast guard
Tags: None
What kind of oil?
How many miles?Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
Interior Whore
- 6380
- fred
- 1996 Camaro z28
im pretty positive pennzoil full syn and prob 300 mileswishing i could drive like joe and the atm squad
Hmmm...check your plugs...I suspect they'd be black...Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
300 miles and black oil is normal, I thought. Mine was black when I changed it at 250.- Brian Meissen
ive found that a 160 degree thermo can make a car run too rich, is that what youve got? The PCM will be referencing the warm-up AFR tables constantly. My oil got dirty quick with that also.-Joel
For break in miles, I'd agree with you.Originally posted by meissen View Post300 miles and black oil is normal, I thought. Mine was black when I changed it at 250.
But full synthetic on a broken in motor?
My suspicions are running in line with Joel's...Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
a 160 tstat is a good idea if your computer is programmed for it - but with the stock AFR tables, the PCM never thinks it reaches operating temperature, and thus the AFR will never quite hit the optimum mixture. 160 is "close" to warmed up, so it will only run somewhat rich - its not extreme or dangerous but it will filth the oil up quicker. The PCM gradually leans the mixture out the warmer the coolant readings get.-Joel
good point - i overlooked that.Originally posted by 81DaytonaPaceCar View PostFor break in miles, I'd agree with you.
My suspicions are running in line with Joel's...- Brian Meissen
Interior Whore
- 6380
- fred
- 1996 Camaro z28
i have a stock thermostat but this is all good info. i just dont have the money for a rebuild quite yet so i was hoping i wasnt seeing early signs of catostrophic failurewishing i could drive like joe and the atm squad
You have an old dirty motor and the new SM rated oils are very good at cleaning so you are probably just seeing the oil do it's job. I would not worry about it. New pennzoil syn is some of the best out there now for the money. If an oil is not getting dirty it is not doing its job I would think.sigpicMODS: SLP DUAL/DUAL EXHAUST, 160 STAT, MTI LID, SHANER S3 T.B., SMOOTH BELLOWS, DESCREENED MAF, TUNNEL BRACE, UMI SFC & PHB, STRANO SWAY BARS, DRILLED/SLOTTED ROTORS, WHISTLER LIGHTS, BLACK BILLET GRILLE w/69'SS EMBLEM, BLACK SMOOTHED TAIL PANEL w/69'SS EMBLEM, BLACK SS HOOD INSERT, INTIMIDATOR SS WHEELS.
This is very true.Originally posted by SSTODD View PostYou have an old dirty motor and the new SM rated oils are very good at cleaning so you are probably just seeing the oil do it's job. I would not worry about it. New pennzoil syn is some of the best out there now for the money. If an oil is not getting dirty it is not doing its job I would think.
If your plugs look normal, I'd say it's nothing to worry about, but keep an eye on it...Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
Isn't royal purple synthetic?- Brian Meissen
