YUP thats what i was thinking that it was the shocks...anyway to make sure its that before i shell the cash to fix it?
Squeaks
when you push on the rear how many times does it bounce up and down? i believe if its more then 1 or 2 they are bad... i cant rememberThe Original
InActive Member- April 8th, 2008
- 34
- Gearhead
- 1969 Camaro, 1979 Camaro, 1981 Camaro, 1983 Firebird
- Pittsburgh, PA
To BigJon's respnonse, if the car bounces more than 3 times the shocks are bad (by PA state inspection standards, anyway). That doesn't mean that the bushings on it aren't bad though. Just the hydraulic part of them.
My guess is that it's a bushing. Possibly shock or trailing arm. Don't count out a misaligned/loose exhaust! If it makes noise while you jounce the car then have somebody jump on it while you poke your head underneath! Or if it's hard to get your ear in there you can use a piece of heater hose to use as a stethoscope.
If there's a squeaking bushing WD-40 or close to it will work to locate the noise, but can get messy. I've found that a strong dishsoap/water mixture in a cheapo squirty bottle works just as well, is much cheaper and cleans at the same time
