suv's and trucks that are ss's also have the iron block 6.0l
LS1 or 383
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
00 Tahoe Z71........Stock
Here is some basic information about the engines and some applications where they can be found
5.3L
***Generation III***
The Vortec 5300, or LM7/LM4/L59/L33, is a V8 truck engine. It is a stroked (by 9 mm) version of the Vortec 4800 and replaced the 5700 L31. L59 denoted a flexible fuel version, while the LM7 was the standard version of the engine.
Power output is 285-295 hp (213-220 kW) and torque is 325 lb·ft (441 N·m) to 335 lb·ft (454 N·m). Displacement is 5.3 L (5328 cc (325 cu in)) from 96.01 mm bore and 92.00 mm stroke. Vortec 5300s are built in St. Catharines, Ontario, Romulus, Michigan, and Silao, Mexico.
LM7
The LM7 Vortec 5300 was introduced in 1999, and can be considered the "garden variety" version of the Generation III 5.3 liter V8's.
LM7 applications:
2002-2005 Cadillac Escalade 2WD
2002-2006 Chevrolet Avalanche
2003-2007 Chevrolet Express/GMC Savana
1999-2007 Chevrolet Silverado 1500
1999-2007 GMC Sierra 1500
1999-2006 Chevrolet Suburban/GMC Yukon XL
1999-2006 Chevrolet Tahoe/GMC Yukon
LM4
The LM4 was an aluminum block version of the LM7, and had a short production life. It should not be confused with the L33.
LM4 applications:
2004 Chevrolet TrailBlazer EXT
2004 GMC Envoy XL
2004 Chevrolet SSR
L33
The L33 was an aluminum block version of the LM7, and was referred to as the Vortec 5300 HO in marketing materials. Power increased by 15 hp (11 kW), to 310 hp (230 kW), over the LM7, and torque was unchanged. It was only available on extended cab 4WD pickup trucks.
L33 applications:
2005-2007 Chevrolet Silverado 1500 4WD
2005-2007 GMC Sierra 1500 4WD
L59
The L59 Vortec 5300 was introduced in 2002, and was a flexible fuel version of the LM7. Power and torque ratings matched that of the LM7.
L59 applications:
2002-2007 Chevrolet Silverado 1500
2002-2006 Chevrolet Tahoe/GMC Yukon
2002-2006 Chevrolet Suburban/GMC Yukon XL
2002-2007 GMC Sierra 1500
6.0L
LQ4
The Vortec 6000, or LQ4, is a V8 truck engine. It is a bored version of the Vortec 5300. Displacement is 6.0 L (≈366 cu in) from 101.6 mm bore and 92 mm stroke. It is an iron/aluminum (2000 model year engines had cast iron heads) design and produces 300 horsepower (220 kW) to 325 horsepower (242 kW) and 360 lb·ft (488 N·m) to 370 lb·ft (502 N·m). LQ4s are built in Romulus, Michigan and Silao, Mexico.
LQ4 applications:
Chevrolet Silverado 2500 Pickup, 3500 Pickup, Crew Cab, and Chassis Cab/GMC Sierra 2500 HD Pickup and Crew Cab, C3, Denali, and 3500 Pickup and Chassis Cab, 1500HD Crew Cab
Chevrolet Suburban/GMC Yukon XL Denali
Hummer H2 SUT
GMC Yukon Denali
LQ9
The Vortec HO 6000 or VortecMAX is a special high-output version of the Vortec 6000 V8 truck engine originally designed for Cadillac. This engine was introduced in other truck lines as VortecMAX for 2006. It features high-compression (10:1) flat-top pistons for an extra 10 hp (7.5 kW) and 10 ft·lbf (14 N·m), bringing output to 345 hp (257 kW) and 380 ft·lb (515 N·m). LQ9s are built only in Romulus, Michigan. GM also listed it as based on LS architecture.[1]
LQ9 Applications:
2002-2006 Cadillac Escalade
2002-2006 Cadillac Escalade EXT
2003-2006 Cadillac Escalade ESV
2003-2007 Chevrolet Silverado SS
2004-2005 Chevrolet Silverado and GMC Sierra Vortec HO Edition Only [Badging on truck]
2006-2007 Chevrolet Silverado and GMC Sierra VortecMAX Option-08 G8 GT DD: Rotofab CAI, HID's, Breyton Race GTS'
Post Whore
- 3000
- Tyler Porter
- student
wikipedia
Thanks for all the info Shawn, it has really been very helpful. The website you posted has some really good deals on the 5.3 & 6.0 engines. I also looked on the forum that AJ posted from TGO and I am have a better understanding of the costs associated with a LS1 swap. I really don't think I can afford the LS1 swap at this time but the truck engine seems more feasible. The TGO forum also made me just want to stay with my origional block & go 383 based on the power goals that I have, although, these truck engines are very appealing as well. I will do some more home work on the prices of doing the 5.3, and 6.0 swap, compared to keeping my origional block and strokinh it to 383.Originally posted by shawnc16 View PostHere is some basic information about the engines and some applications where they can be found
5.3L
LM7
LM7 applications:
LM4
LM4 applications:
2004 GMC Envoy XL
2004 Chevrolet SSR
L33
L33 applications:
L59
L59 applications:
6.0L
LQ4
LQ4 applications:
Hummer H2 SUT
GMC Yukon Denali
LQ9
LQ9 Applications:
An example of one member's costs when starting with the truck engine. Of course yours wont be the same but it's a good insight as majority of it will apply.
6.0L Swap.zipMakin Torque.
You can go cam only 5.3 or 6.0 and be able to obtain that 350 rwhp pretty easily. Not only will it make the power you want but, it will be more reliable and wont leak oil like EVERY single sbc does.-08 G8 GT DD: Rotofab CAI, HID's, Breyton Race GTS'
Post Whore
- 3000
- Tyler Porter
- student
my sbc doesnt leak a damn thing. either does my truck91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
Thanks for posting this AJ, I looked at the numbers and I would just but a complete 6.0 with wiring harness, accessories and all becasue I woudn't know how to piece a bare block together. Buy a 4l60E, but looking at spencers build it looks like the swap wouldn't just go right into my third gen. I would also have to pay for labor as well. I am going to talk to my mechanic about going 6.0 to see if it is a feasible project financially for me.Originally posted by Iroc'nthe87 View PostAn example of one member's costs when starting with the truck engine. Of course yours wont be the same but it's a good insight as majority of it will apply.
[ATTACH]34323[/ATTACH]
Actually, the 6.0 can and will just bolt right in. Get adapter plates from ebay (1" setback plates 3/8" thick) They allow you to bolt your existing engine mounts to the LS block. Oh for $40...
For exhaust you can use the stock manifolds from an Fbody. Im sure there are plenty of members here with some manifolds laying around.
Buy the Fbody accessories (Balancer, waterpump, ETC)Last edited by shawnc16; March 6th, 2011, 08:55 PM.-08 G8 GT DD: Rotofab CAI, HID's, Breyton Race GTS'
