HAHA mine are off completely but that's because i grabbed them and the rubber fell off haha! But id love to get a set of the aftermarket ones...just havent gotten around to it lol
Here's where I'm at with this project as of now...
Started by getting the STB off and unbolting the shocks/springs from above. Who's idea was it to put the one torx bolt underneath the mater cylinder on the driver's side? What a PITA...
Found some light surface rust or corrosion on the underside of the upper A-Arm mounting area - I'm going to clean the area and tape off a small area and hit it with POR-15 to make sure it never comes back.
I'm going to leave the lower A-arms and Spindles on the car and paint them in place, rather then tearing it all apart - I'm planning on tubular A-Arms eventually anyways.
The pictures below show how lucky I was to have had the shocks replaced a few thousand miles ago. These things should be cake to get apart and should be salvageable. I'm going to have a shop disassemble them and install my new springs - not worth dying over for the $20 they'll probably charge to do the work.
Had to again cut the sway bar end links in half - planned on replacing them anyways. I have a new set of MOOGs in the garage and the bar and links will be finished to match the rear (red).
Calipers and brackets are also being painted currently. I've got 3 coats of Duplicolor caliper paint on them so far, should be fine
I think that's about it for now... some progress pics below.
And one picture of how the car sits right now............
man this thing is gonna be soo clean...it makes me jealous i wish i had the time/money to do appearance mods on my car
Some pictures of the upper A-arms (they have 2 coats of POR-15 on them as of now). Also some pictures of the shocks after disassembly and cleaning up the threads a bit.
SOLD-1967 Buick Skylark
Well, she's all put back together, just need to bleed the brakes!
I couldn't wait to see the new stance, so I slapped the wheels on and and set it down on the ramps (too much work to set it on the ground without a low-pro jack). I'm very happy with it so far!
