<Project> 2000 Trans Am
  • damn youre getting up there in having as many haters as me.. lol 10 inch wide rears will fit just fine.. just all depends on the offset.. i have 10.25's and i have at least another inch of clearance on my car to the rim itself
    • Originally posted by kammi10 View Post
      lol... just what I always wanted!
      Well, I think I'll get the 10.5" rears and run a 295 tire. If I HAVE to massage the inners I will *cringe* ... what about like a 5-10mm spacer?
        If you need a spacer, you got the wrong offset
        • Especially with your car lowered it may give you problems - just want you to be prepared.
          • Thanks guys! Well I think I'll just order them and adjust my car as necessary. These are what I'll be going with... in a couple weeks.
            http://www.oewheelsllc.com/Wheels-fo...25822-3-1.html
            • just remember fred, i got a cut off wheel you can borrow as well as a 40lb. sledge if need be!
              • Originally posted by ThreeHonks View Post
                I'll be sure to call ya! Mini-tub anyone? Might need an air chisel too...
                • i got one of those too! got an axe as well and a chainsaw. all essential tools for working on an f body
                    ...the American way
                      Lol, my ass. Mini-tub requires or indicates SOME form of power. Unless you find a way for that turd to get out of its own way, save your time, money and energy!
                      (how's that? your serve...)
                      • Originally posted by OVRKILL View Post
                        Why do you think I had the windows tinted? I can hide from the embarrassment of driving this pile....
                        • Wheels have been ordered!!
                          Tire suggestions for...?
                          Rear: 295/35/18
                          Front: 275/35/18
                            Rear: 295/35/18
                            Front: 275/35/18
                            IMO just get 275 35s on all four corners that way you can rotate them. the extra 20mm isn't going to make a difference.
                            • Originally posted by bri2203 View Post
                              i beleivce the rears are a wider rim.. therefore making it so he cant rotate..
                              those sizes sound good fred.. rear tires will be about a half inch taller then the fronts which will be just fine..
                              ORDER UM UP!!!!
                                ORDER UM UP!!!!
                                I wasn't aware of that. Makes more sense now
