Originally posted by 96mikez28
View Post
Official blown 10 bolt list
automatic in a way...you still gotta shift 'em!1998 Camaro SS Bullseye Turbo
actually youre one of the only people ive ever seen build a car in the correct order.Originally posted by 96mikez28 View PostI got some of the stuff out of the way(torque arm, driveshaft, brakes) and will be ordering my 9" tommorow . I know i'll get flamed for having a 9" on a bolt-on car this year, but I don't feel like spending all the money to fix my 10 bolt this just to have it blow up next year under 383 power ( i can't afford to build my 383 this year and set the car up to handle it too)-Joel
i blew mine at ubly last year in oct. was an auburn prostreet with richmond fat gears moser axles and on 4th lauch kaplow. what a noise. only 5 months with it and less than 3000 miles. got a eaton in it now but maybe next year go with a 12 bolt or a nine inch.
Yea mike I dont see anything wrong with the way you are doing it.
And Jeff dont worry your not the only one. I dont have $2G sitting around for it.
yeah i didnt have 2g around when i blew mine so i rebuild it. But next time hopefully 2 years. ( if it lasts ) ill get a ford 900 ws6 vert a4 ( mods in garage )
87 fullsize bronco ( 35 inch mud terrains )
85 iroc ( lt1 and 6 speed )
honda 450r
honda 400ex gf's
I think whats holding mine together is the fact that it hasnt been touched from factory.-Joel
- March 29th, 2006
- 1080
- Eric H
- 1997, Pontiac, Trans Am
- Middleville, MI
- Chemical Tech.
Just curious what happens if you flow them at the track. How do they get your car off the track? I was told that if your rear makes a mess they charge you for clean up?
most of the time when ten bolts blow you just strip the ring gear. usually you just push the car off the track.-Joel
- March 29th, 2006
- 1080
- Eric H
- Middleville, MI
- Chemical Tech.
I've never seen it happen at the track. I know for a fact if it happens they aren't exactly going to remove your car "dent free" I've seen them tow cars off the track before with real bumpers. What do they do?? Just drag it off the track? Hopefully my nittos don't cause mine to go boom this yearOriginally posted by JoeliusZ28 View Postmost of the time when ten bolts blow you just strip the ring gear. usually you just push the car off the track.
