6.0 piston slap
    Usually only last a minute on cold start. I have seen them go 300k without issue
    Yep, I would leave it alone.
      Originally posted by Boost Addict View Post
      Too rich for my blood. Seen an 03 at Zemkos go for $900 with 31k.
      I have less than that into both motors, but that's my "don't think twice" price
        Figure out a "I will accept $xxx if you pick up this weekend price"
        2015 Silverado
          I'm Dutch, I don't mind hanging on to things for a LONG time.
          $999
            Drop it drop it low
            2015 Silverado
              $9.99
              Does that include Delivery to GR?
              — Thomas Jefferson
                i still want your 5.3
                  let me find more out about both motors. 5.3 has the typical 862 heads, 6.0 has the 317's
                    Jeremy, I was going to ask about the exhaust it but slipped my mind. I remember seeing some in there and was wondering if that was for the car or not.
                      Back to the top.
                      Pistons pulled. Cleaned the bores with my new 320grit flex hone. The 3 cylinders aren't perfect but they are a LOT better, and good enough for the girls I run with (which is nothing to laugh at )
                      Pistons - would you guys run a moly or moly/teflon coating on the pistons? I can get this done for free since it would be a "product test" for my friend's company.
                      Rings - I bought new Mahle moly rings, well, the kit with the moly coated top ring anyway. What are people gapping these LSx motors at?
                      Rod bearings - they look pretty good, but I think I'll get new anyway (unless this isn't advised)
                        Also looking for a good used cam. I'd like to find a cheap 2002-04 z06 cam and valve springs.
                        If I find some extra cash laying around I would like a TSP 228r and some PAC 1218 springs
                          Ive got my TR224 I pulled out earlier this year.
                            Price?
                              300?
                                I'll pass on that, I don't like paying much for used cams. Thanks for letting me know!
