Engine Oil Filter Study
  • Engine Oil Filter Study
    http://people.msoe.edu/~yoderw/oilfilterstudy/oilfilterstudy.html
    Found this and thought I would post it.
    Pennzoil & Quaker State (which is owned by Pennzoil) oil filters are the same as the Fram.
    http://people.msoe.edu/~yoderw/oilfilterstudy/oilfilters.html
    He says Fram is a bad filter. I've been running them since I could drive (only 2 years now) and haven't had any problem. I believe Jasen has been running them for awhile. So I don't know.
    Another good oil site. http://www.bobistheoilguy.com/
    Holley 650cfm Double Pumper
    Edelbrock Performer-Plus Cam
    I have seen that article before, it's pretty interesting. I don't know how much I would trust one person's opinion but it's good to know nevertheless. Thanks for posting the link. I know I have a Firestone oil filter because I don't really change my own oil since I live in an apt.
      I've always used Fram myself too, but in a v6 who cares what you use.
        I try to avoid Frams if at all possible. I've read several things that say Frams are the worst filters. I've been running Purolator Pure One micronic filters now for about 8 years. It sucks that Meijer stopped carrying them. Now I have to go way out of my way to either an Advanced Auto or Pep Boys to pick them up. I think the Pure One filters were 2nd only to the Mobil 1 filters at like a third the price.
        Wade
          I recently did a bunch of research on this and yes I've ran Fram for years, yes there is still one in my car, but only until I change the oil. Fram has a cheap paper element. The problem with that is, they overcharge you for it and don't tell you its no better than a Duesch (or whatever that's called that Autozone carries) because its in a pretty orange package. There has also been problems with the paper element tearing and getting into main bearings and spinning the bearings.
          From the reasearch I've done if I remember correctly, the Mobil 1 & K&N filters are the best, followed by the Purolater and Wix which is sold by NAPA as a NAPA filter. So I'll be going to the K&N filter and switching to Royal Purple from Mobil 1 when I do it . Not that there is anything wrong with mobil 1, I just want to try Royal Purple.
          Here's some threads to read that were sent to me.......
          http://ls1tech.com/forums/showthread...ram+oil+filter
            That's all i use is Royal Purple, its good stuff if you can afford $7 a quart, and for the oil filter i have always used Fram, never had any problems
              Hell, Mobil 1 is around $6 a quart anyway, what's another $5-$6 for RP. I've never had a problem with any of my fram's either, just want to be sure, play it safe.
                Yes Sir!
                  I use valvoline filters when I change mine each time.
                  5th gen Camaro V6 Forums
                  http://www.bowtiev6.com
                    i waste 10.99 on the mobil 1 filters but it gives me peace of mind
                    ~Phil
                      Originally posted by Orange Terror
                      I ... Fram has a cheap paper element. The problem with that is, they overcharge you for it and don't tell you its no better than a Duesch (or whatever that's called that Autozone carries) because its in a pretty orange package. There has also been problems with the paper element tearing and getting into main bearings and spinning the bearings.
                      This is the very reason I will not use a fram filter. I have tried them a couple of times. The last one damn near cost me a engine in my Cutlass. nothing like finding bits of paper in the oil when changing it. Dropped the pan and cleaned out and flushed the engine. Luckily no major damage. FRAMs response to the problem "Sorry, But its Not our Problem". No more frams for me. I only use purolator now or AC if I have the dealer do it.
                      — Thomas Jefferson
                        AC DELCO and MOBIL 1 are always a good decision... FRAM IS CRAP
                        "ANY car can be an SS but ONLY a Camaro can be a Z28!" Scott S.
                        "Owning a 9 second import is like coming out of the closet. At first you surprise everyone, but in the end you're still gay!"
                          I have been using K&N Gold in my 3.8l v6 since I bought the car back in 2002. No problems yet. No particals in oil when replacing it. Plus I love the socket end on the filter . I hate using oil wrenches.
                            The pure one's arnt bad but....
                            Long Live AMZOIL!
                            AMZOIL! AMZOIL! AMZOIL!
                              Do you go to the Firestone at 16 and Van Dyke? I just started workin there
                              Cobra isn't just a mustang, but an ancronym for Cars Owned By Retarded *******s.
