Hoping to hear some not so bad news tomorrow! Hoping for the best Mike!
best rods for the cost? blown motor? WTF?
Grammar Nazi
- January 10th, 2006
- 6647
- Jonny
- under par
- Huron Speed
tear it down and see what the problem is before you start looking at what u think u need!!!!!Originally posted by formula z View Postanyways whats the best place, brand, and price for what i may need, like a crank and rods? Im seriously hoping my cylinder walls are not trash. Guess i better just try to calm down until i see what i find tomorrow
Yea the last thing I would worry about is looking at parts and prices. Gets rather overwhelming really fast.
I deffiently think it has to do with valve train tho. I would went with double springs just for extra insurance. Yea they are more expensive and heavier but I wouldn't run any even somewhat built motor without them.
Let us know the verdict tomorrow!!!
Also did the car shake real bad like the motor was out of balance?
Hopefully you find an easy(er) fix under the valve covers!1998 Camaro SS Bullseye Turbo
passenger sidecar damage 015.jpgdriver sidecar damage 013.jpgcar damage 014.jpg
everything looks and feels good. all springs, retainers, valves and rockers are in good shape from i can see and feelsigpic
- - 5.3/4L80e/T7875 - -
- Huron Speed Turbo Kit -
1998 Formula
did you take out the push rods and see if one is bent? roll them on a flat surface98 z28, m6, monster clutch, eibach pro kit, custom twin turbo setup, 317 heads, z06 valve springs, arp rod bolts, 512rwhp at 10lbs. cobra eater
i'd try that. did you pull your spark plugs? might have detonated and flattened one. thats what happened to me.. i got on it a little too much before my tune... after i pulled valve covers rocker arms, and push rods, checked everything, i pulled my plugs and number 7 was bent inOriginally posted by Formula Z View Postno i havent done that. only have pulled the covers so far98 z28, m6, monster clutch, eibach pro kit, custom twin turbo setup, 317 heads, z06 valve springs, arp rod bolts, 512rwhp at 10lbs. cobra eater
