I think my Dutch heritage got the best of me when I heard "I have a low miles LT1 cam you can have."
Engine specs:
355 4 bolt hydraulic roller
10.5:1
Heads:
Edelbrock 80659 - 2.02/1.60 with .010 Mill (165cc 232/175 cfm)
Lunati 74818K5 valve spring kit (+.100 valves, 130# seat at 1.800")
Comp Cam High Energy 1.5 roller rockers
Intake:
Accel Superram baseplate
SLP runners
Matched plenum
Stock TB with SLP air foil
Exhaust:
Hooker 2055's Ceramic with AIR tubes
Magnaflow 3" cat (not on the car)
Hooker 16823 catback (not on the car)
Current Cam:
Comp Cams custom grind.
LT1 3196B/3120B HR111 E C8553
Installed dot to dot.
Looking at Comp's Lobe catalog:
3196 Intake
Duration - 288
Duration @ .050 - 236
Duration @ .200 - 162
Lift -.585
3120 Exhaust
Duration - 304
Duration @ .050 - 244
Duration @ .200 - 161
Lift -.575
The car starts up just fine, when it's cold I might have to fire it up two or three times then it will stay running. Haven't played with the cold start delay yet. I can't get the AEM wideband to read at idle ("---") and smells rich, the smell is to be expected with 74* of overlap but I thought I'd see something measurable on the o2. 32* of timing at idle, idle set to 900 RPM at operating temp. 8 inHg at idle.
Worth spending the cash to put the car on the dyno for a tune? Or should I pull out the cam while I have the front bumper off the car?
Engine specs:
10.5:1
Heads:
Intake:
SLP runners
Matched plenum
Exhaust:
Current Cam:
3196 Intake
Duration - 288
Lift -.585
3120 Exhaust
Duration - 304
Lift -.575
