went to the track and went to depress the clutch to get it out of 3rd and the clutch pedal was solid as a rock! got it by the time slip booth and a buddy came by and pushed it down breaking my slave cylinder off. i replaced the slave, and now its still solid as a rock! btw i drove it home from the track with no clutch! so i know the clutch is still ok/engaged. any thoughts of what it could be?
clutch pedal stuck up!
1997 Camaro SS convertible #455 30th anv #80 -
wow that sucks! how did you manage driving home with no clutch??? I can shift without using the clutch, but you still have to press it to come to a stop. im trying to think what could cause that.-Joel
you shut the car off put it in gear then roll it over while in gear. its kinda tricky but it worked
He won't hurt the forks too bad. The worst damage will be when the syncho rings get all stretched out from having to synchonize the gears under the weight of the whole car. Once the synchos are ruined, he'll be double-clutching every gear change to keep from grinding the gears. Don't know what double-clutching is? Ask gramps or and old time truck driver.
Interior Whore
- January 21st, 2008
- 6380
- fred
- 1996 Camaro z28
- U.P. and over you.
- united states coast guard
double clutching is pushing in the clutch shifting to nuetral release the clutch push clutch back in and then shift into desired gearOriginally posted by MarkIV427 View PostHe won't hurt the forks too bad. The worst damage will be when the syncho rings get all stretched out from having to synchonize the gears under the weight of the whole car. Once the synchos are ruined, he'll be double-clutching every gear change to keep from grinding the gears. Don't know what double-clutching is? Ask gramps or and old time truck driver.
. i looked it up after the fast and furious when don (vin desiel) said "not double clutching like u shoud"
trans is new, so no concerns there, but we took the slave back off and the clutch fork is stuck in, and wont come back, so we have to take the trans back out
care to explain how that happens??? Ive never heard of that.Originally posted by 1BADAIR View Postdisk(friction surface) came loose and slid over I bet.-Joel
ok, so basically a friction "puck" couldve come undone and flown out... makes sense.-Joel
what kind of clutch do you have?-Joel
