View Post
Gears??
The Joke Master
- June 30th, 2005
- 8513
- Jasen
- Grand Rapids
- Mechanical Designer
X2, Personally I'd look at 3.42's or 3.55's first. But then again I loved the 3.23 ratio I had on my 99 that was an auto. I'd also recommend leaving the gears alone and getting a converter instead. And, you can do that yourself to, if you need help, I'm sure somebody here would help.Originally posted by TSTONE View Post373's are about as stout as id go
X2 if you don't get the teeth lined up to spec you can destroy your rear end! If you have not done this process before I would not suggest trying it. Also, used gears can be in rough shape sometimes especially since the only people who would choose to upgrade their rear end gears most likely will be racing the car or at least driving more aggressively. Oh and make sure you change the gear lube when if you do it.Originally posted by s.reef View Postive heard gear install can be a tad tricky if you havent done it before for somethin like that i would probably look at taking it to a mechanic.
The Joke Master
- June 30th, 2005
- 8513
- Jasen
- Grand Rapids
Considering that when you pull the cover the oil/gear lube is going to come out no matter what I would really hope nobody would put the old used lube back in after changing the gears. That would just be foolish and asking for trouble.Originally posted by phoenix_rising View PostX2 if you don't get the teeth lined up to spec you can destroy your rear end! If you have not done this process before I would not suggest trying it. Also, used gears can be in rough shape sometimes especially since the only people who would choose to upgrade their rear end gears most likely will be racing the car or at least driving more aggressively. Oh and make sure you change the gear lube when if you do it.
As with any and all used parts, do a thorough inspection before you buy and with gears make sure the ring & pinion gear are the matching set as they should be worn in together. So long as there isn't cracks or visible stress they should be fine. Also, new or used, get a new pinion bearing pressed on, that way you know its good. I'd also recommend to anyone that has no experience to get help from someone that knows what they are doing or get a book, better yet both if possible.
x3...a 3.23 gear is a good all around gear. I personally wouldn't waste the money on gears at all.Originally posted by Orange Terror View PostI'd also recommend leaving the gears alone and getting a converter instead.Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
24 of longnecks....Originally posted by JoeliusZ28 View Posthow much do you charge for gear installs in terms of beer?
you might have a customer.
That'd be tits but I'd probably forget to put in a shim or something after playing beer pong on your hoodOriginally posted by Z28ISGR8 View PostI second that. I'll bring a Keg if thats what it takes.
would you need anything besides the gearset, gasket, and fluid? I might bring an axle up to you later this springOriginally posted by ITSSLOW View Post24 of longnecks....
Might as well put new bearings and seals in while your there.Originally posted by JoeliusZ28 View Postwould you need anything besides the gearset, gasket, and fluid? I might bring an axle up to you later this spring
good call-Joel
Ring and Pinion, gasket (or RTV), gear oil, and it would be smart to go bearings while you have it apart. Gonna need a shim pack too...2005 Yamaha R6
alright ill check into it all, thanks mane!-Joel
i can help you with long tubes i'm only in lake orion, they are pretty easy, i've done them on a lift and with a jack, you getting rid of the emissions crap right?
i was gonna do gears but i figure why waste the money on a 10 bolt if its just gonna break.sigpic
The LS1 or Go Home Crew
ASE master certified
Im shooting towards the end of march to have all the stuff together...ill pm you with a list of stuff later and you can tell me what else i amy need.2011 Ford Raptor SuperCrew
