Gears??
  • Gears??
    I was thinking about upgrading my gear ratio from stock 3.23 to somthing else. I don't think I really want 4.10's but I want something more aggressive than the stock gearing. Anyone have any suggestion's as to what I should get?
    99 Camaro Z28 A4
    maybe a 3.73, my buddy shawn aka 96blackbetty has that ratio in hisT/A
      I would not put 4:10s in an auto car go with 3:73s
        Get a converter 1st....... Than you wont even think about gears when you cant hook 1st and half of 2nd.
          Dammit Campbell. I don't got that kinda money to throw around man. Gears and headers are affordable and we can install them ourselves. I'll bring the beer
          99 Camaro Z28 A4
            So your going to pay $500 for gears and an install over another $200 for a converter that will yield better gains and you can install it yourself...
              500 for gears? the hell kinda gears r u looking at? I can get a nice set of used headers and gears, total, for like 6 hundred and we can install.
              99 Camaro Z28 A4
                Well I'll help you put the headers in but I'm not touching that rear end...
                  fine then. I'll ffind sum used ones than well get r done.
                  99 Camaro Z28 A4
                    ive heard gear install can be a tad tricky if you havent done it before for somethin like that i would probably look at taking it to a mechanic.
                      A gear swap is no problem but then again I've done like 20 of them and am ASE certified.
                      Just my .02 but in an A4 car I'd run 3.73 over a 4.10. I'm only planning on putting 3.90's in my car and I have an M6.
                        So when we doin my camswap and gear install
                          When you ordering the stuff?
                            Broke 3 teeth off in my old WS6 due to a shitty install of 4.10s by the previous owner. The smell of that fluid literally makes me gag. That being said, it was a fun day of work to repair it.
                              how much do you charge for gear installs in terms of beer? you might have a customer.
