Gears??
    how much do you charge for gear installs in terms of beer? you might have a customer.
    I second that. I'll bring a Keg if thats what it takes.
    99 Camaro Z28 A4
      373's are about as stout as id go
        X2, Personally I'd look at 3.42's or 3.55's first. But then again I loved the 3.23 ratio I had on my 99 that was an auto. I'd also recommend leaving the gears alone and getting a converter instead. And, you can do that yourself to, if you need help, I'm sure somebody here would help.
          Originally posted by s.reef View Post
          ive heard gear install can be a tad tricky if you havent done it before for somethin like that i would probably look at taking it to a mechanic.
          X2 if you don't get the teeth lined up to spec you can destroy your rear end! If you have not done this process before I would not suggest trying it. Also, used gears can be in rough shape sometimes especially since the only people who would choose to upgrade their rear end gears most likely will be racing the car or at least driving more aggressively. Oh and make sure you change the gear lube when if you do it.
            Considering that when you pull the cover the oil/gear lube is going to come out no matter what I would really hope nobody would put the old used lube back in after changing the gears. That would just be foolish and asking for trouble.
            As with any and all used parts, do a thorough inspection before you buy and with gears make sure the ring & pinion gear are the matching set as they should be worn in together. So long as there isn't cracks or visible stress they should be fine. Also, new or used, get a new pinion bearing pressed on, that way you know its good. I'd also recommend to anyone that has no experience to get help from someone that knows what they are doing or get a book, better yet both if possible.
              x3...a 3.23 gear is a good all around gear. I personally wouldn't waste the money on gears at all.
                24 of longnecks....
                That'd be tits but I'd probably forget to put in a shim or something after playing beer pong on your hood
                  Originally posted by ITSSLOW View Post
                  24 of longnecks....
                  would you need anything besides the gearset, gasket, and fluid? I might bring an axle up to you later this spring
                    Might as well put new bearings and seals in while your there.
                      good call
                        Ring and Pinion, gasket (or RTV), gear oil, and it would be smart to go bearings while you have it apart. Gonna need a shim pack too...
                          alright ill check into it all, thanks mane!
                            24 of longnecks....
                            HA yea well if I end up doing it, you'll be the one I'am lookin for
                            99 Camaro Z28 A4
                              i can help you with long tubes i'm only in lake orion, they are pretty easy, i've done them on a lift and with a jack, you getting rid of the emissions crap right?
                              i was gonna do gears but i figure why waste the money on a 10 bolt if its just gonna break.
                              The LS1 or Go Home Crew
                              ASE master certified
                                24 of longnecks....
                                Im shooting towards the end of march to have all the stuff together...ill pm you with a list of stuff later and you can tell me what else i amy need.
