LT1 Engine Bay
    As you can see in the pics above I also removed the ABS. It junk and my brakes work great. Also you can just take the bulb out, I don't have a ABS light on.
      whats up with all these people with hot air intakes off ebay on their cars?
        Kinda like the way mine looks.....
          Lol. Cause I couldn't fined anything for a ls1 in a lt1 car. So I need to make something. And I was only waiting on a intake to drive the car. So walah a cheap intake.
            If you guys want to argue the pros and cons of ABS, take it to PMs. This thread is about cleaning up the engine bay.
            Cleaned up the thread.
              Mine has a long ways to go but here's what it looks like -
              Canton Valve Covers
              Painted Intake Manifold
              Aftermarket Intake Elbow
              SLP Cold Air Intake
              Mallory Billet Accessories (MBA) billet dress up all over (caps, covers, etc)
              MBA Radiator Shroud
              Cleaned and painted alternator with MBA alternator fan (no longer have the pulley cover on it)
              Taylor's Over The Valve Cover spark plug wire setup (though I plan to switch to a standard setup sometime down the road)
              UMI Strut Tower Brace
              !passenger wire mod
              Fuel line relocation
              Painted the engine bay
              My dad painted the under side of the radiator support black which I thought was a cool effect
              Polished stainless steel hard brake lines going into and out of the ABS and master cylinders
              Polished the AC lines on the passenger side and the accumulator
              [ATTACH=CONFIG]44329[/ATTACH]
              [ATTACH=CONFIG]44330[/ATTACH]
              What'd you do with all the wires that go along the passenger side fender?
              1997 Trans Am
              T56 swap. LS1 Cosmetics
                I believe he ran them into the wheel well.
                  Yeah - !passenger wire mod. Drill a hole in the strut tower right infront of the PCM and then reroute the wires between the underside of the strut tower and the plastic splash guard / wheel liner.
                  This winter I want to reroute the hood latch cable on the driver's side - then I'll have 100% "clean" strut towers since I did the !passenger wire mod and the fuel line relocation.
                    thanks brian
                      swomp_rat and i have actually done a couple of cars deleting the wire harness... have it down to a science... passenger side, drivers side and hood latch cable
                        Sweet, post a how-to or at least some pics, I would love to do that to mine, it's the only real eye-sore left.
                        96 Z28 Camaro M6
                        2008 Silverado quad cab LTZ
                          Thats it ? only 3 people have pics of their lt1 ?
                            I have pics but its currently stock. With headers going in, and all the emissions being blocked off it should clean it up a but. But its hard enough keeping the exterior clean living down a dirt road let alone the engine bay.
                            Sent from my broken out Pantech Breakout using Tapatalk
                            1994 Formula - http://www.fquick.com/garages/viewvehicle.php?id=52284
                            http://freepatriot.org
                              ok got my computer back and its trashed... but he did get my pics off the hard drive.. heres my lt1peoria 9.JPGpeoria 10.JPGpeoria 11.JPGpeoria 12.JPGTilted kilt 2.JPG
                                Here is a couple
