Dont know how to do it properly, need some advice. i know you have to thoroughly clean it, sand it with something very fine, and then paint. i have black appliance epoxy would that work?
Painting chrome
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
Painting chrome
00 Tahoe Z71........Stock
97 K1500 lt4 cam, 1.6s, MPFI, Solid axled, IROKs,------winter beater -
Yeah, I sanded my wife's running boards and sprayed with rhino liner.. Lasted about 6 months and started flaking off..Originally posted by OVRKILL View Postto do it right, you have to take the chrome off....down to the copper at least.
Maybe I should say, I scuffed them...sigpic
Is that possible without throwing all kinds of benjamins in the wind?Originally posted by OVRKILL View Postto do it right, you have to take the chrome off....down to the copper at least.
Im going to see if chasis saver works out for the base-coat of the accents on my chrome 10 spoke SS wheels.-Joel
i helped my buddy do this we sanded those mofo for ever then used a really good primer then paint... powder coat will be your friend sirThe Original
nothing wont stick to smooth surfaces, sand them the 320, then 600, primer them, wet sand 600 prime again wet sand, clean wax and grease remover paint and clear'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
Post Whore
- 3000
- Tyler Porter
- student
well i contacted duplicolor not too long ago, and then said epoxy would work best if you dont want it to flake off. im not a paint expert but it just doesnt sound right. ill end up sanding the crap out of it, i think a self etching primer would work but id have to find one that wouldnt negatively react with the epoxy.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
Is money an object? Lol....Originally posted by JoeliusZ28 View PostIs that possible without throwing all kinds of benjamins in the wind?
Chemically stripped is best...not sure on cost.
Tyler, what are you wanting to paint?sigpic
Is there a way you can safely do this on part of the wheel and not all of it? Would duct tape work for masking? I'd like these 35th wheels to come out right.Originally posted by WMCCjames View PostGrit blast with aluminum oxide then paint.-Joel
Obsessed
- April 23rd, 2011
- 561
- David.
- 1997 formula firehawk and 69 chevelle.
- jackson Mi
- auto body painter well i recenly have been forced to retired due to health problems.
Ok I have done this painting them is not the best way to do this but if you are going to do so you need to etch that Chrome good so I would get a fine sand and blast them don't try and remove the chrome just etch them make them dull . Most chrome aluminum wheel will pit badly then a good apoxy will stick well then a good paint will be best. Now a better way would be to litely blast as I said earlyer then have them powder coated I've done this and it worked very well . If your rich have the chrome chemicaly removed that's. Best. Or new wheelssigpic1997 firehawk # 115 6 speed. Its just a little ole LT1
when you say fine sand what grit are you referring to ? cause to me "fine" or "finish" sand paper is 1000 to 6000 grit. which is not what you want to use to prep any type of surface for primary paint or clear.Originally posted by 97firehawk View PostOk I have done this painting them is not the best way to do this but if you are going to do so you need to etch that Chrome good so I would get a fine sand and blast them don't try and remove the chrome just etch them make them dull . Most chrome aluminum wheel will pit badly then a good apoxy will stick well then a good paint will be best. Now a better way would be to litely blast as I said earlyer then have them powder coated I've done this and it worked very well . If your rich have the chrome chemicaly removed that's. Best. Or new wheels'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
Yep, there is special masking tape for this purpose, its made from PVC. Duct tape could work but it will not last nearly as long as the good stuff. Alot depends on what grit size and pressure you use. Aluminum oxide generates heat and the heat is what kills the masking.Originally posted by JoeliusZ28 View PostIs there a way you can safely do this on part of the wheel and not all of it? Would duct tape work for masking? I'd like these 35th wheels to come out right.
Also, don't ever use straight sand..the silica is very harmful to your health.sigpicTurbo Charged LS1/T56
