Huron Speed 5th Gen -Turbo Kit
  • Huron Speed 5th Gen -Turbo Kit
    Well I figured it is well overdue to step into the 5th gen game. With a few turbo kits on the market, I still have really yet to find a real nice quality kit that has a good customer support backing and can make a decent power number, let along one that can do this at a reasonable price!
    I have a lot going on right now, but I feel this was a necessity to grow the business! I was searching around and found the perfect candidate! Should work real well being bone stock, and hold its value well for when I need to move on from it.
    Plans:
    Once I get my new area set up, insulated, dry-walled, lift install, and all tools moved in this will be the first project!
    -Single T4 turbo kit that retains all creature comforts
    -Will fit any T4 turbo from a basic 3" v-band exit unit to a big turbine wheel'd mid-frame!
    -Plan is to make a full 4" down pipe standard with a stainless header design.
    -Complete with all items needed to install it less your components as we will add those in based on your goals, performance needs, and budget!
    Also we will use this to show off more of our hydrographics work, and hopefully quite a few more products as well along with the turbo system!
    2012 45th Anniversary SS, Manual Trans
    Nice! Looking forward to watching this project!
      Very nice! Just curious any thought of doing this on the V6 motors? Or will that not work so well with the high compression DI setups? Just pipe dream thought, a turbo v6 would be a killer DD.
        If you need a v6 project car....
          badass car! Do you have a horse power number that you are looking for?
            Being that the kit's goal is to fit a numerous amount of different turbos, power numbers should be able to range from the 500-1150 rwhp mark!
              I agree, a turbo set-up for the V6 cars would be great. Figuring out what it likes and would take is something I would have to research.
              Brian, once I wrap this V8 kit up, I would love to do it, would need the car for a week or so
                We could make that happen.
                  Sounds good, you're my man!
                    I'm excited to see where this goes.
                      Hmm, this is going to be good...
                        1997 Trans Am
                        T56 swap. LS1 Cosmetics
                          Originally posted by JasonH
                            subscribed for HSP awesomeness
                              oooooh im anticipating this build.
                              00 Tahoe Z71........Stock
