Bump Stops
    Originally posted by csmith4153 View Post
    Its not a group buy. Just something I've been waiting to come in. Brian asked me about them a long time ago, and they are now in stock.
    You can order from my site with a credit card.
    http://cs3automotive.com/index.php?a=PROD:227
    If anyone need to pay by PayPal, shoot me a pm with your info. I'll need to figure out shipping cost. Spay the heck out of your bolts with WD-40, BP Blaster or some Kroil oil (I might of spelld that wrong) and Let it soak in, spray it more, soak, etc...
    This is a picture of the lip thats need to be cut out of the way
    I have no clue what year my Camaro subframe is on the '55....
    (looks to be a 1ST. Gen )... My stop go's on the bottom...
    **** FEAR THIS ! ***
      I'll try to take a look at my 69 this weekend and see if I can match something up for you.
      2011 Camaro SS
      1999 Camaro SS #4153
      1986 Monte Carlo SS
      1969 Camaro - 427 Rat
        THANKS Creight ...
          Originally posted by 1qwikSS View Post
          Is there any way to get a angle grinder or small air powered disc wheel in there to put a straight slot on the bolthead to use a flathead screwdriver to get them out?
          Dunno- I don't have an angle grinder or any pneumatic tools.
              Tried it - the smallest bit is too big for the bolt head.
                It looks like the Energy Bump stops are shorter than stock and we may need these too...
                http://dagostinoracing.com/bmz_cache...ge.400x175.jpg
                http://www.hawksthirdgenparts.com/ca...newgm-1-1.aspx
                Or for 17" wheels
                http://www.hawksthirdgenparts.com/ca...opnewgm-1.aspx
                  I used just the Energy Stops and I've been perfectly fine with them - no tire rubbing on the inside of the fender or anything with my 17"
                    so will I have a prob using these if I go with 17 inch wheels on a tirdgen?
                    99 Buick Regal GS- New DD
                    SOLD-1967 Buick Skylark
                      I didn't, but I don't have a 3rd gen. Try it and see, if you notice rubbing then get the spacers.
                        I bought the same ones as Brian and they work perfect on my 3rd gen but then again I only have 16 inch wheels but I think they would be fine with 17's as well...
                          sad part is I cannot afford 17s for awhile so I will slowly buy what I can, IF I can keep the car..
                            Your 1st link shows the spacer that SLP used on the SS's. SLP has them on clearance. I dont stock them, but SLP has them for $20.00
                            http://www.slponline.com/view_product.asp?P=80046
                            The other stuff from Hawks is just the Energy Suspension bump stops with and extra 100 bucks added for some spacers. I can look into have spacers made to make these 100% bolt-in, but I need more then 1 person commited to make it happen.
                            2011 Camaro SS
                            1986 Monte Carlo SS
                              so let me get this straight, the bump stops are not just the aluminum plates with no rubber or urethane on them, they are bump stops.. like factory but nicer..
                              cause I saw the raw aluminum pics and thought that was all there was. Which was not gonna do what I needed, but the ones that you put in your post are for 93-02 not 82-92.. whats the diff?
                                The poly pieces are the actual bump stop. The aluminum makes the bump stop the same height as stock. Hawks 3rd gen sells them and recommends using spacers. I bought the bump stops and I will probably get the spacers too since I have 17" wheels.
