Air Lift 1000 Drag Bags are an add on helper for coil spring equipped cars. Particularly helpful on drag cars where the rear suspension needs to be pre-loaded for the car to launch straight. Air lifts improve sixty foot times and increase traction. All kits includes two air bags, two inflation valves, all fittings, air lines, and mounting hardware.
You still need an air compresser and pump for these right?
I'd imagine if you want to put air in them you need an air comp. But my question is can you use any regular air comp.? I have a little 2 hp one, would that work?
98 Trans Am WS.6 Cam
Heads
Intake
Full exhaust
More mods to come
I've had a set of these on our '85 IROC-Z for years. The rear started to sag a bit with the sub cabinet, amps and stuff in the rear well. I added these and run about 12-15 psi, just enough to level the car again. They work great for that.
I run a "T" fitting in the lines so both have the same pressure, and only have one fill valve.
RIP Doug,You will always be remembered
3/3/53 ~ 12/22/10 Western Michigan Camaro Club - President 2002 Hot Rod Magazine Ltd. Ed. by Berger 1985 Camaro IROC-Z 1974 Camaro Type LT / Z28 2002 Trail Blazer LTZ 2003 Honda VFR 800i Interceptor
Air is air for them, you can even fill them with one of the little cheapo cigarette lighter air compressors. Heck....if you REALLY wanted, you could use a bicycle pump!
Wade 2002 Camaro SS T Top Black M6 SLP 345HP 1985 Camaro IROC Z28 T Top Silver 305TPI Auto
need a set for the Buick not the bird, thanks for the info though..
99 Buick Regal GS- New DD
SOLD-1967 Buick Skylark
