Did you get in touch with that guy you said you know?
WTB: cts-v brakes
Enthusiast- January 1st, 2009
- 342
- Chris
- 1987,Chevy,Camaro(IROC)
- Jenison, Mi
- Gentex production maintenance
About having to run a rear spacer ? that's just about the type of wheel someone runs and different offsets. There isn't anything wrong with his product its just the rear calipers is thicker then a stock rear 3rd or 4th gen caliper'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
I believe they're both using 4th gen rear axles...............____ .......
________|___\____
|__(O)__|____|_(O)|
I had had meant to say solid rear axles, the axles move causing some knockback, or moving the pad away from the rotor under load. I would think a sliding rear caliper would be better for this situation, but i havent really researched it all that much.Originally posted by mikewoods View PostI believe they're both using 4th gen rear axles.1998 Pontiac Firebird T/A, M6, LT Headers, ORY, Borlamouth, tubular LCA and Panhard bar, lowered 1.5". More to come
fixed rear calipers, 3rd or 4th gen rear, my rear didn't have much play, another fix would be thicker c clips. regardless it would be very small knockback.'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
- 342
- Chris
- Jenison, Mi
Yeah from what I am told is if your rear end has minimal end play you won't have pad knockback.
i am trying to figure out how you can get oem ac delco bream I calipers for $140/piece yet everyone wants $600 for a used set of calipers.Air Force/Afghanistan veteran
1987 Iroc camaro Supercharged 5.3
2012 Toyota tacoma
this is true. mine was really minimal so I left itOriginally posted by sweet_87_iroc View PostYeah from what I am told is if your rear end has minimal end play you won't have pad knockback.'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
to fix that for track guys, just run thicker c clips, axles wont move so much then'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
- 342
- Chris
- Jenison, Mi
No track running for this guyAir Force/Afghanistan veteran
2012 Toyota tacoma
- 342
- Chris
- Jenison, Mi
Damn that is crazy close!Air Force/Afghanistan veteran
2012 Toyota tacoma
