LS FRONT BRAKES NEEDED ASAP
  • LS FRONT BRAKES NEEDED ASAP
    I am in need of ls front brakes.I need calipers,spindles,brackets...let me know price,location,and condition of calipers...Cash in hand
    I should have all of that. Calipers would be used, pull from a friends parts car, but still in good shape. I will get you some pictures of everything tomorrow if your interested.
    Located in Goodrich/Ortonville area.
      Yes I am...also let me know price..
        Thanks,I found everything i needed..
          Question???will the stock Ls calipers clear 15 inch rims??If not,how much grinding is needed on the caliper?
            They fit most 16" wheels fine, but 15's...now your getting into custom work.
              Im running weld pro stars...is there any write ups on making the Ls brakes work with these rims?
                from my understanding, you have to do some grinding on the calipers a bit. mike and larry both did it i think?
                  Do you know if there is a write up on it??My head is aching from all the empty searches I have found..lol...I really want to use these brakes with my pro stars..I am about 450.00 into these brakes..New drilled and slotted rotors,new calipers,spindles,pads..One guy I found said thats all he needed to run was the 5/16 spacer,I tried that and the calipers still grind on the rim..Starting to get a little frustrated now..lol
                    U still need ls1 calipers I got some fresh red paint and 1person bleeder skrews 100 brackets to text me 3134775310
                      you will need to grind the front calipers on LS front brakes for pro stars to fit.
                        and rears.
                        Welds are an old design and require quite a bit of grinding if I recall.
                        I'm not sure what you were searching for but this took me literally 10 seconds to find.
                        http://www.ls1tech.com/forums/drag-r...ers-101-a.html
                          I actually did find that write up yesterday...I already have the rears taken care of.and I odered Race Stars for the front..
