I am in need of ls front brakes.I need calipers,spindles,brackets...let me know price,location,and condition of calipers...Cash in hand
LS FRONT BRAKES NEEDED ASAP
from my understanding, you have to do some grinding on the calipers a bit. mike and larry both did it i think?98 z28, m6, monster clutch, eibach pro kit, custom twin turbo setup, 317 heads, z06 valve springs, arp rod bolts, 512rwhp at 10lbs. cobra eater
Do you know if there is a write up on it??My head is aching from all the empty searches I have found..lol...I really want to use these brakes with my pro stars..I am about 450.00 into these brakes..New drilled and slotted rotors,new calipers,spindles,pads..One guy I found said thats all he needed to run was the 5/16 spacer,I tried that and the calipers still grind on the rim..Starting to get a little frustrated now..lol
you will need to grind the front calipers on LS front brakes for pro stars to fit.Doing less with more
and rears.Originally posted by DETROITMUSCLE View Postyou will need to grind the front calipers on LS front brakes for pro stars to fit.
Welds are an old design and require quite a bit of grinding if I recall.
I'm not sure what you were searching for but this took me literally 10 seconds to find.
http://www.ls1tech.com/forums/drag-r...ers-101-a.html
