headers and a clutch
  • headers and a clutch
    Pace setter long tubes. if you have them, and they are in good shape. I want them.
    I'm also looking for a good deal on a street/strip clutch. Do NOT want a stock OEm clutch, won't hold up. Need something better like a high pressure stage 1.
    I do have money so let me know what you have. Thanks
    96 Z28 Camaro M6
    2008 Silverado quad cab LTZ
    Pretty sure Rolando has some ceramic coated pacesetters and a Y for sale.
    Used to own a Firebird.
      i bought my monster stage 2 from texas speed. got a super good deal on it shipped to my door along with slave cylinder
        check out these guys for a clutch ->http://www.competitionclutch.com/
        I have had mine in for about 1500 miles and absolutely love it, you wont hear much bad things about them either.
          Yeah I remember when you were telling that other dude about it. As soon as I read that I went to that site and you can't touch them for that deal now. You got a steal! What kind of clutch do you run anyways?
          96 Z28 Camaro M6
            lol nevermind.. I see that's the first thing you said.
            96 Z28 Camaro M6
              man they have some real attractive prices. I'm liking that PT# 4134-2600 clutch for 339.00. Could someone explain to me what all that "DOM B facings" and Side SB stuff means. Would this clutch be a direct swap in my 96Z? thanks
              96 Z28 Camaro M6
                That I did. Sold two days ago. But mine were for an LS1
                  Not sure what the DOM D stuff means but its made exactly for your 96 Z, they come with everything you need to do the install. Mine went it very smooth and after about 400 mi break in it is a very nice clutch.
                  http://competitionclutch.com/store/d...hp?vinvid=6669
                    Well atleast I know who Rolando is now,lol. Hey Rolando, if you come across any headers from friends or whatever, could you let me know?? Thanks!
                    96 Z28 Camaro M6
                      hmmm.. somethings up with that link. Just takes me to an empty page that says 'Product Detail", but shows nothing else. Idk, could be my shitty work computers. These things blow. But as far as that part# I provided goes, that should be good right? They rate it up to 700ish torque. I won't be touching that. 500-550lb ft at the most, with close to that same HP.
                      96 Z28 Camaro M6
                        they rate it to 700hp, and you have to remember thats HP at the flywheel so factoring out the 15% ish drivetrain loss. What are your mods?
                          I have Competition Clutch model# 4134-2250. It drives like stock and is rated at 550hp (so about ~440-450rwhp being conservative with drivetrain loss). It also lists for $299 and I got mine for $240 from a dealer a couple years ago. Personally unless you were over 400rwhp I wouldn't bother getting a more aggressive clutch without trying that one first, it's too cheap to not give it a chance since you say you're replacing a stock clutch and just want something with a little more holding power.
                            I also have the 2250, it is great.
                              Well mods right now are just bolt-ons. But I'm getting serious this summer. I just have full exhaust and a trick flow intake, B&M Ripper shifter,LCA's, SFC's, all the free mods.. basically stock,lol. But since this OEM clutch is slipping all the way down the track, I figured I'd start there. The most I will do is heads, cams, dyno tune, headers. But you're right, for 299.00, even if it didnt hold up later down the road, who cares. For now it will be far sufficient for what I need. Thanks man, this helped tons. I was about to drop 500.00 at summit for a clutch! I've put clutches(and full tranny's) in front-wheel drive cars. this shouldn't be any worse than that right??
                              96 Z28 Camaro M6
