Mine is 3 channel, 3.23 open diff. Also includes girdle cover and LCA relocation brackets. No brake backing plates, e-brake cables, rotors. I do have a set of crap calipers that you can have to use as cores to get new ones. Also properly painted (prepped with marine clean and etched with metal ready) with POR-15:
I am looking for a rear end with the Torsen style limited slip differential which was used in 99+ F-bodies.
It should also have the 3.42 ratio used with the 6-speed.
Steffen, you're better off hitting up www.car-part.com to find what you need and/or eBay. Try the seller sulery on eBay. He's the guy I bought most of my swap stuff from. The last time I checked, he had a ton of 99+ rear axles in 3.42 with lsd.
