Decided to pull the trigger and upgrade to LS1 front brakes on my car. I will need calipers and spindles (I plan on getting new pads and rotors anyway). Anybody got some sitting around they'll let go for cheap?
Wanted: LS1 brake stuff
- February 19th, 2010
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
Originally posted by JasonHIt's amazing what you can get done when you throw copious amounts of money at something. -
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
I looked the other day on Tech and didn't say something. I probably won't be buying from the guy in that thread though...don't feel like shipping from Italy
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
bump, I think I'm getting calipers from sman, but I still need spindles. Anybody have anything? Otherwise I'll just resort to car-part.com
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
also, are spindles different from 98-02 V6 cars versus V8 cars?
Did you get my PM on the spindle? I also have a brand new set of ceramic brake pads for LS1, front and rear. Taking up space in the garage.2011 Ford Raptor SuperCrew
No, and up until last month, I had a set of those too.Originally posted by alone_and_insane View Postalso, are spindles different from 98-02 V6 cars versus V8 cars?
Deal on the calipers BTW, Ill see if I can get to blasting them tomorrow morning super early or later tonight. Only things you should need are the seals for the pistons and maybe the boots for the slide pins.1999 Camaro - 6 liters of fury.....
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
I did get your PM on the spindle, I would like to find both in the same place if I could. And how difficult is it to replace the stud?Originally posted by s.reef View PostDid you get my PM on the spindle? I also have a brand new set of ceramic brake pads for LS1, front and rear. Taking up space in the garage.
easy. Gently tap out old one. Get a new one and use washers and open lug to tighten it back on2011 Ford Raptor SuperCrew
InActive Member
- November 18th, 2007
- 439
- Mike
- 2002 Camaro LS1 M6
- Ortonville Michigan
- Fork lift repainter
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
I think I'm just going to do the front conversion. How much do you want for just the fronts?
